Investigating Relationships Between FLOSS Foundations and FLOSS Projects - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Foundations function as vital institutional support infrastructures for many of the most successful open source projects, but the role of these support entities remains an understudied phenomenon in FLOSS research. Drawing on Open Hub (formerly known as Ohloh) data, this paper empirically investigates the different ways these entities support projects and interact with different projects and with each other.
432701_1_En_2_Chapter.pdf (565.58 Ko) Télécharger le fichier
hal-01776260 , version 1 (24-04-2018)
Paternité
Juho Lindman, Imed Hammouda. Investigating Relationships Between FLOSS Foundations and FLOSS Projects. 13th IFIP International Conference on Open Source Systems (OSS), May 2017, Buenos Aires, Argentina. pp.14-22, ⟨10.1007/978-3-319-57735-7_2⟩. ⟨hal-01776260⟩
149 Consultations
60 Téléchargements
