A case study of optimal input-output system with sampled-data control: Ding and al. force and fatigue muscular control model - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2018
The objective of this article is to make the analysis of the muscular force response to optimize electrical pulses trains using Ding et al. force-fatigue model. A geometric analysis of the dynamics is provided and very preliminary results are presented in the frame of optimal control using a simplified input-output model. In parallel, to take into account the physical constraints of the problem, partial state observation and input restrictions, an optimized pulses train is computed with a model predictive control, where a nonlinear observer is used to estimate the state-variables.
bakir_bonnard_rouot_NHM.pdf (1.33 Mo) Télécharger le fichier
hal-01779349 , version 1 (26-04-2018)
hal-01779349 , version 2 (26-04-2018)
Toufik Bakir, Bernard Bonnard, Jérémy Rouot. A case study of optimal input-output system with sampled-data control: Ding and al. force and fatigue muscular control model. 2018. ⟨hal-01779349v1⟩
824 Consultations
409 Téléchargements
