New interface
Journal articles
Time minimal saturation of a pair of spins and application in magnetic resonance imaging
Abstract : In this article, we analyze the time minimal control for the saturation of a pair of spins of the same species but with inhomogeneities of the applied RF-magnetic field, in relation with the contrast problem in Magnetic Resonance Imaging. We make a complete analysis based on geometric control to classify the optimal syntheses in the single spin case to pave the road to analyze the case of two spins. The Bocop software is used to determine local minimizers for physical test cases and Linear Matrix Inequalities approach is applied to estimate the global optimal value and validate the previous computations. This is complemented by numerical computations combining shooting and continuation methods implemented in the HamPath software to analyze the structure of the time minimal solution with respect to the set of parameters of the species. Symbolic computations techniques are used to handle the singularity analysis.
Document type :
Journal articles
Complete list of metadata
Cited literature [38 references]  Display  Hide  Download
https://hal.inria.fr/hal-01779377
Contributor : Jérémy Rouot Connect in order to contact the contributor
Submitted on : Friday, January 4, 2019 - 2:13:09 PM
Last modification on : Friday, November 25, 2022 - 10:12:06 AM
Long-term archiving on: : Friday, April 5, 2019 - 2:12:56 PM
File
mri_2019.pdf
Identifiers
Citation
Bernard Bonnard, Olivier Cots, Jérémy Rouot, Thibaut Verron. Time minimal saturation of a pair of spins and application in magnetic resonance imaging. Mathematical Control and Related Fields, 2020, 10 (1), pp.47-88. ⟨10.3934/mcrf.2019029⟩. ⟨hal-01779377v3⟩
Share
Metrics
Record views
1516
Files downloads
888
