REDUCTION BY SONICATION OF EXCESS SLUDGE PRODUCTION IN A CONVENTIONAL ACTIVATED SLUDGE SYSTEM CONTINUOUS FLOW AND LAB-SCALE REACTOR
Conventional activated sludge wastewater treatment plants currently produce a large quantity of excess sludge. To reduce this sludge production and to improve sludge characteristics in view of their subsequent elimination, an ultrasonic cell disintegration process was studied. In a lab-scale continuous flow pilot plant, part of the return sludge was sonicated by low-frequency and high-powered ultrasound and then recycled to the aeration tank. Two parallel lines were used, one as a control, and the other as an assay with ultrasonic treatment. Reactors were continuously fed with synthetic domestic wastewater with a COD of approximately 0.5 g l –1 corresponding to a daily load of 0.35–0.50 kg COD kg –1 TS d –1. Removal efficiencies (carbon, particles), excess sludge production and sludge characteristics (particle size distribution, mineralization, respiration rate, biological component) were measured every day during the 56-day experiment. This study showed that while organic removal efficiency was not deteriorated, excess sludge production was decreased by about 25–30% by an ultrasonic treatment. Several hypotheses are advanced: (i) the treatment made a part of the organic matter soluble as a consequence of the floc disintegration and optimized the conversion of the carbonaceous pollutants into carbon dioxide and (ii) the treatment modified the physical characteristics of sludge by a mechanical effect: floc size was reduced, increasing the exchange surface and sludge activity. The originality of this study is that experiments were conducted in a continuous-flow activated sludge reactor rather than in a batch reactor.
