Floating-point arithmetic in the Coq system - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2008
The process of proving some mathematical theorems can be greatly reduced by relying on numerically-intensive computations with a certified arithmetic. This article presents a formalization of floating-point arithmetic that makes it possible to efficiently compute inside the proofs of the Coq system. This certified library is a multi-radix and multi-precision implementation free from underflow and overflow. It provides the basic arithmetic operators and a few elementary functions.
08-rnc8-article.pdf (171.17 Ko) Télécharger le fichier
hal-01780385 , version 1 (27-04-2018)
  • HAL Id : hal-01780385 , version 1
Guillaume Melquiond. Floating-point arithmetic in the Coq system. 8th Conference on Real Numbers and Computers, Jul 2008, Santiago de Compostela, Spain. pp.93-102. ⟨hal-01780385⟩
Collections
INRIA
94 Consultations
110 Téléchargements
