Embedding Camassa-Holm equations in incompressible Euler - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Geometric Mechanics Année : 2019
In this article, we show how to embed the so-called CH2 equations into the geodesic flow of the Hdiv metric in 2D, which, itself, can be embedded in the incompressible Euler equation of a non compact Riemannian manifold. The method consists in embedding the incompressible Euler equation with a potential term coming from classical mechanics into incompressible Euler of a manifold and seeing the CH2 equation as a particular case of such fluid dynamic equation.
CH computational_v1.pdf (369.21 Ko) Télécharger le fichier
hal-01781162 , version 1 (29-04-2018)
Andrea Natale, François-Xavier Vialard. Embedding Camassa-Holm equations in incompressible Euler. Journal of Geometric Mechanics, 2019. ⟨hal-01781162⟩
388 Consultations
168 Téléchargements
