Journal articles
The Rank Pricing Problem: models and branch-and-cut algorithms
Abstract : One of the main concerns in management and economic planning is to sell the right product to the right customer for the right price. Companies in retail and manufacturing employ pricing strategies to maximize their revenues. The Rank Pricing Problem considers a unit-demand model with unlimited supply and uniform budgets in which customers have a rank-buying behavior. Under these assumptions, the problem is first analyzed from the perspective of bilevel pricing models and formulated as a non linear bilevel program with multiple independent followers. We also present a direct non linear single level formulation bearing in mind the aim of the problem. Two different linearizations of the models are carried out and two families of valid inequalities are obtained which, embedded in the formulations by implementing a branch-and-cut algorithm, allow us to tighten the upper bound given by the linear relaxation of the models. We also study the polyhedral structure of the models, taking advantage of the fact that a subset of their constraints constitutes a special case of the Set Packing Problem, and characterize all the clique facets. Besides, we develop a preprocessing procedure to reduce the size of the instances. Finally, we show the efficiency of the formulations, the branch-and-cut algorithms and the preprocessing through extensive computational experiments.
Complete list of metadatas
https://hal.inria.fr/hal-01782958
Contributor : Concepción Domínguez <>
Submitted on : Monday, December 3, 2018 - 3:05:41 PM
Last modification on : Tuesday, September 29, 2020 - 12:24:14 PM
Long-term archiving on: : Monday, March 4, 2019 - 3:04:20 PM
File
RPP_dic_2018.pdf
Identifiers
Collections
Citation
Herminia Calvete, Concepción Domínguez, Carmen Galé, Martine Labbé, Alfredo Marin. The Rank Pricing Problem: models and branch-and-cut algorithms. Computers and Operations Research, Elsevier, 2019, 105, pp.12-31. ⟨10.1016/j.cor.2018.12.011⟩. ⟨hal-01782958v3⟩
Share
Metrics
Record views
207
Files downloads
583
