An extreme quantile estimator for the log-generalized Weibull-tail model
A new estimator for extreme quantiles is proposed under the log-generalized Weibull-tail model, ntroduced by (de Valk, C., Extremes, pp. 661--686, vol. 19, 2016). This model relies on a new regular variation condition which, in some situations, permits to extrapolate further into the tails than the classical assumption in extreme-value theory. The asymptotic normality of the estimator is established and its finite sample properties are illustrated both on simulated and real datasets.
