Variationally consistent discretization schemes and numerical algorithms for contact problems, Acta Numerica, vol.6, pp.569-734, 2011. ,
DOI : 10.1016/j.cma.2005.06.003
URL : https://hal.archives-ouvertes.fr/hal-01382364
Towards a complete numerical description of lubricant film dynamics in ball bearings, Computational Mechanics, vol.95, issue.3???5, pp.239-255, 2014. ,
DOI : 10.1016/0045-7825(92)90141-6
Computational fluid dynamics and full elasticity model for sliding line thermal elastohydrodynamic contacts, Tribology International, vol.46, issue.1, pp.3-13, 2012. ,
DOI : 10.1016/j.triboint.2011.04.013
URL : https://hal.archives-ouvertes.fr/hal-00655930
Modelling of fluid???structure interactions with the space???time finite elements: Solution techniques, International Journal for Numerical Methods in Fluids, vol.195, issue.6-8, pp.855-900, 2007. ,
DOI : 10.1002/nme.788
3D fluid???structure-contact interaction based on a combined XFEM FSI and dual mortar contact approach, Computational Mechanics, vol.62, issue.9, pp.53-67, 2010. ,
DOI : 10.1007/978-3-642-56767-4
A partitioned fluid???structure algorithm for elastic thin valves with contact, Computer Methods in Applied Mechanics and Engineering, vol.197, issue.19-20, pp.1750-1761, 2008. ,
DOI : 10.1016/j.cma.2007.03.019
URL : https://hal.archives-ouvertes.fr/inria-00111991
Fluid-structure interaction and multibody contact: Application to aortic valves, Computer Methods in Applied Mechanics and Engineering, vol.198, pp.45-46, 2009. ,
DOI : 10.1016/j.cma.2008.09.012
URL : https://hal.archives-ouvertes.fr/inria-00300770
3. An accurate Eulerian approach for fluid-structure interactions, Fluid-Structure Interaction: Modeling, Adaptive Discretization and Solvers, Radon Series on Computational and Applied Mathematics, 2017. ,
DOI : 10.1515/9783110494259-003
URL : https://hal.archives-ouvertes.fr/in2p3-00020007
??ber ein Variationsprinzip zur L??sung von Dirichlet-Problemen bei Verwendung von Teilr??umen, die keinen Randbedingungen unterworfen sind, Abhandlungen aus dem Mathematischen Seminar der Universit??t Hamburg, vol.12, issue.1, pp.9-15, 1970. ,
DOI : 10.1007/BF02161362
A Nitsche-Based Method for Unilateral Contact Problems: Numerical Analysis, SIAM Journal on Numerical Analysis, vol.51, issue.2, pp.1295-1307, 2013. ,
DOI : 10.1137/12088344X
URL : https://hal.archives-ouvertes.fr/hal-00717711
Symmetric and non-symmetric variants of Nitsche???s method for contact problems in elasticity: theory and numerical experiments, Mathematics of Computation, vol.84, issue.293, pp.1089-1112, 2015. ,
DOI : 10.1090/S0025-5718-2014-02913-X
A Nitsche finite element method for dynamic contact: 1. Space semi-discretization and time-marching schemes, ESAIM: Mathematical Modelling and Numerical Analysis, vol.49, issue.2, pp.481-502, 2015. ,
DOI : 10.1007/s00466-007-0196-4
URL : https://hal.archives-ouvertes.fr/hal-00958695
A mixed formulation for frictional contact problems prone to Newton like solution methods, Computer Methods in Applied Mechanics and Engineering, vol.92, issue.3, pp.353-375, 1991. ,
DOI : 10.1016/0045-7825(91)90022-X
An adaptation of Nitsche??s method to the Tresca friction problem, Journal of Mathematical Analysis and Applications, vol.411, issue.1, pp.329-339, 2014. ,
DOI : 10.1016/j.jmaa.2013.09.019
Nitsche-based finite element method for contact with Coulomb friction, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01654487
Galerkin least squares finite element method for the obstacle problem, Computer Methods in Applied Mechanics and Engineering, vol.313, pp.362-374, 2017. ,
DOI : 10.1016/j.cma.2016.09.025
Lack of Collision Between Solid Bodies in a 2D Incompressible Viscous Flow, Communications in Partial Differential Equations, vol.336, issue.9, pp.1345-1371, 2007. ,
DOI : 10.1142/S0218202506001303
Collisions of smooth bodies in viscous fluids: A mathematical investigation, University of Minnesota, 2004. ,
Collisions in Three-Dimensional Fluid Structure Interaction Problems, SIAM Journal on Mathematical Analysis, vol.40, issue.6, pp.2451-2477, 2009. ,
DOI : 10.1137/080716074
The influence of boundary conditions on the contact problem in a 3D Navier???Stokes flow, Journal de Math??matiques Pures et Appliqu??es, vol.103, issue.1, pp.1-38, 2015. ,
DOI : 10.1016/j.matpur.2014.03.005
URL : https://hal.archives-ouvertes.fr/hal-00795366
Regularity Issues in the Problem of Fluid Structure Interaction, Archive for Rational Mechanics and Analysis, vol.421, issue.5, pp.375-407, 2010. ,
DOI : 10.1017/S0022112000001695
Strong solutions for the fluid?solid systems in a 2-d domain, Asymptotic Analysis, vol.89, pp.3-4 ,
Existence of Global Strong Solutions to a Beam???Fluid Interaction System, Archive for Rational Mechanics and Analysis, vol.8, issue.12, pp.1283-1333, 2016. ,
DOI : 10.1007/s00021-003-0083-4
URL : https://hal.archives-ouvertes.fr/hal-01138736
Mathematical and Numerical Analysis of Some FSI Problems, pp.1-77, 2014. ,
DOI : 10.1007/978-3-0348-0822-4_1
Existence of a weak solution to a fluid???elastic structure interaction problem with the Navier slip boundary condition, Journal of Differential Equations, vol.260, issue.12, pp.8550-8589, 2016. ,
DOI : 10.1016/j.jde.2016.02.029
A 3D mortar method for solid mechanics, International Journal for Numerical Methods in Engineering, vol.59, issue.3, pp.315-336, 2004. ,
DOI : 10.1002/nme.865
Two dimensional mortar contact methods for large deformation frictional sliding, International Journal for Numerical Methods in Engineering, vol.50, issue.9, pp.1183-1225, 2005. ,
DOI : 10.1017/CBO9781139171731
Adaptive finite element approximation of fluid-structure interaction based on an Eulerian variational formulation Fluid-Structure Interaction: Modeling, Simulation, Optimization, Lecture Notes in Computational Science and Engineering, pp.110-145, 2006. ,
Eulerian formulation and level set models for incompressible fluid-structure interaction, ESAIM: Mathematical Modelling and Numerical Analysis, vol.8, issue.3, pp.471-492, 2008. ,
DOI : 10.1007/BF01084616
URL : https://hal.archives-ouvertes.fr/hal-00297711
A Fully Eulerian formulation for fluid???structure-interaction problems, Journal of Computational Physics, vol.233, pp.227-240, 2013. ,
DOI : 10.1016/j.jcp.2012.08.047
An energy stable monolithic Eulerian fluid-structure finite element method, International Journal for Numerical Methods in Fluids, vol.116, issue.C, pp.430-446, 2017. ,
DOI : 10.1016/S0045-7825(94)80025-1
URL : https://hal.archives-ouvertes.fr/hal-01326785
Flow patterns around heart valves: A numerical method, Journal of Computational Physics, vol.10, issue.2, pp.252-271, 1972. ,
DOI : 10.1016/0021-9991(72)90065-4
A finite element approach for the immersed boundary method, Computers & Structures, vol.81, issue.8-11, pp.491-501, 2003. ,
DOI : 10.1016/S0045-7949(02)00404-2
Immersed finite element method, Computer Methods in Applied Mechanics and Engineering, vol.193, issue.21-22, pp.2051-2067, 2004. ,
DOI : 10.1016/j.cma.2003.12.044
An Eulerian???Lagrangian method for fluid???structure interaction based on level sets, Computer Methods in Applied Mechanics and Engineering, vol.195, issue.17-18, pp.2070-2087, 2006. ,
DOI : 10.1016/j.cma.2005.02.025
An eXtended Finite Element Method/Lagrange multiplier based approach for fluid???structure interaction, Computer Methods in Applied Mechanics and Engineering, vol.197, issue.19-20, pp.1699-1714, 2008. ,
DOI : 10.1016/j.cma.2007.07.002
An unfitted Nitsche method for incompressible fluid???structure interaction using overlapping meshes, Computer Methods in Applied Mechanics and Engineering, vol.279, pp.497-514, 2014. ,
DOI : 10.1016/j.cma.2014.07.007
URL : https://hal.archives-ouvertes.fr/hal-00918272
Nitsche-XFEM for the coupling of an incompressible fluid with immersed thin-walled structures, Computer Methods in Applied Mechanics and Engineering, vol.301, pp.300-335, 2016. ,
DOI : 10.1016/j.cma.2015.12.015
URL : https://hal.archives-ouvertes.fr/hal-01149225
A Nitsche-based cut finite element method for a fluid-structure interaction problem, Communications in Applied Mathematics and Computational Science, vol.96, issue.2, pp.97-120, 2015. ,
Nitsche's method combined with space???time finite elements for ALE fluid???structure interaction problems, Computer Methods in Applied Mechanics and Engineering, vol.193, issue.39-41, pp.39-41, 2004. ,
DOI : 10.1016/j.cma.2003.09.029
An immersogeometric variational framework for fluid???structure interaction: Application to bioprosthetic heart valves, Computer Methods in Applied Mechanics and Engineering, vol.284, pp.1005-1053, 2015. ,
DOI : 10.1016/j.cma.2014.10.040
Numerical methods for immersed FSI with thin-walled structures, 2018. ,
Adaptive finite element approximation of fluid-structure interaction based on Eulerian and arbitrary lagrangian-Eulerian variational formulations, 2007. ,
A Locally Modified Parametric Finite Element Method for Interface Problems, SIAM Journal on Numerical Analysis, vol.52, issue.5, pp.2315-2334, 2014. ,
DOI : 10.1137/130919489
A second order time-stepping scheme for parabolic interface problems with moving interfaces, ESAIM: Mathematical Modelling and Numerical Analysis, vol.258, issue.4, pp.1539-1560, 2017. ,
DOI : 10.1016/j.cma.2013.02.010
Ghost penalty, Comptes Rendus Mathematique, vol.348, issue.21-22, pp.21-22, 2010. ,
DOI : 10.1016/j.crma.2010.10.006
URL : https://hal.archives-ouvertes.fr/inria-00543248
Finite Elements for Fluid-Structure Interactions. Models, Analysis and Finite Elements, Lecture Notes in Computational Science and Engineering, vol.118, 2017. ,
DOI : 10.1007/978-3-642-33134-3_7
Eulerian finite element methods for interface problems and fluid-structure interactions, p.21590, 2016. ,
On the Stabilization of Finite Element Approximations of the Stokes Equations, pp.11-19, 1984. ,
DOI : 10.1007/978-3-663-14169-3_2
A finite element pressure gradient stabilization??for the Stokes equations based on local projections, Calcolo, vol.38, issue.4, pp.173-199, 2001. ,
DOI : 10.1007/s10092-001-8180-4
URL : https://hal.archives-ouvertes.fr/inria-00343043
A new finite element formulation for computational fluid dynamics: V. Circumventing the babu??ka-brezzi condition: a stable Petrov-Galerkin formulation of the stokes problem accommodating equal-order interpolations, Computer Methods in Applied Mechanics and Engineering, vol.59, issue.1, pp.85-99, 1986. ,
DOI : 10.1016/0045-7825(86)90025-3
Edge stabilization for the generalized Stokes problem: A continuous interior penalty method, Computer Methods in Applied Mechanics and Engineering, vol.195, issue.19-22, pp.2393-2410, 2006. ,
DOI : 10.1016/j.cma.2005.05.009
Fictitious domain finite element methods using cut elements: II. A stabilized Nitsche method, Applied Numerical Mathematics, vol.62, issue.4, pp.328-341, 2012. ,
DOI : 10.1016/j.apnum.2011.01.008
Modified Newton Solver for Yield Stress Fluids, Numerical Mathematics and Advanced Applications ENUMATH 2015, pp.481-490, 2016. ,
DOI : 10.1016/j.powtec.2009.09.001
An edge-based pressure stabilisation technique for finite elements on arbitrarily anisotropic meshes, 2017. ,
On the pressure approximation in nonstationary incompressible flow simulations on dynamically varying spatial meshes, International Journal for Numerical Methods in Fluids, vol.44, issue.7, pp.1045-1064, 2012. ,
DOI : 10.1002/fld.679
The finite element toolkit Gas- coigne3d ,
An unconstrained integral approximation of large sliding frictional contact between deformable solids, Computers & Structures, vol.153, pp.75-90, 2015. ,
DOI : 10.1016/j.compstruc.2015.02.027
URL : https://hal.archives-ouvertes.fr/hal-00937569
An unbiased Nitsche???s formulation of large deformation frictional contact and self-contact, Computer Methods in Applied Mechanics and Engineering, vol.325, pp.265-288, 2017. ,
DOI : 10.1016/j.cma.2017.07.015
