KL-UCB-switch: optimal regret bounds for stochastic bandits from both a distribution-dependent and a distribution-free viewpoints - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Machine Learning Research Année : 2022
We consider $K$-–armed stochastic bandits and consider cumulative regret bounds up to time $T$. We are interested in strategies achieving \emph{simultaneously} a distribution-free regret bound of optimal order $\sqrt{KT}$ and a distribution-dependent regret that is asymptotically optimal, that is, matching the $\kappa\ln T$ lower bound by Lai and Robbins (1985) and Burnetas and Katehakis (1996), where $\kappa$ is the optimal problem-dependent constant. This constant $\kappa$ depends on the model $\mathcal{D}$ considered (the family of possible distributions over the arms). M{\'e}nard and Garivier (2017) provided strategies achieving such a bi-optimality in the parametric case of models given by one-dimensional exponential families, while Lattimore (2016, 2018) did so for the family of (sub)Gaussian distributions with variance less than $1$. We extend this result to the non-parametric case of all distributions over $[0,1]$. We do so by combining the MOSS strategy by Audibert and Bubeck (2009), which enjoys a distribution-free regret bound of optimal order $\sqrt{KT}$, and the KL-UCB strategy by Capp{\'e} et al. (2013), for which we provide in passing the first analysis of an optimal distributiondependent $\kappa\ln T$ regret bound in the model of all distributions over $[0,1]$. We were able to obtain this non-parametric bi-optimality result while working hard to streamline the proofs (of previously known regret bounds and thus of the new analyses carried out); a second merit of the present contribution is therefore to provide a review of proofs of classical regret bounds for index-based strategies for K–armed stochastic bandits.
KL-UCB--GHMS.pdf (5.08 Mo) Télécharger le fichier
hal-01785705 , version 1 (04-05-2018)
hal-01785705 , version 2 (05-11-2019)
hal-01785705 , version 3 (28-06-2022)
  • HAL Id : hal-01785705 , version 3
Aurélien Garivier, Hédi Hadiji, Pierre Ménard, Gilles Stoltz. KL-UCB-switch: optimal regret bounds for stochastic bandits from both a distribution-dependent and a distribution-free viewpoints. Journal of Machine Learning Research, 2022, 23 (179), pp.1-66. ⟨hal-01785705v3⟩
440 Consultations
716 Téléchargements
