CoNLL-UL: Universal Morphological Lattices for Universal Dependency Parsing - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2018
Amir More
  • Fonction : Auteur
  • PersonId : 1031761
Çağri Çöltekin
  • Fonction : Auteur
  • PersonId : 1031763
Nizar Habash
  • Fonction : Auteur
  • PersonId : 986779
Dima Taji
  • Fonction : Auteur
  • PersonId : 1031764
Reut Tsarfaty
  • Fonction : Auteur
  • PersonId : 1031765
Following the development of the universal dependencies (UD) framework and the CoNLL 2017 Shared Task on end-to-end UD parsing, we address the need for a universal representation of morphological analysis which on the one hand can capture a range of different alternative morphological analyses of surface tokens, and on the other hand is compatible with the segmentation and morphological annotation guidelines prescribed for UD treebanks. We propose the CoNLL universal lattices (CoNLL-UL) format, a new annotation format for word lattices that represent morphological analyses, and provide resources that obey this format for a range of typologically different languages. The resources we provide are harmonized with the two-level representation and morphological annotation in their respective UD v2 treebanks, thus enabling research on universal models for morphological and syntactic parsing , in both pipeline and joint settings, and presenting new opportunities in the development of UD resources for low-resource languages.
more2018.pdf (159.79 Ko) Télécharger le fichier
hal-01786125 , version 1 (05-05-2018)
  • HAL Id : hal-01786125 , version 1
Amir More, Özlem Çetinoğlu, Çağri Çöltekin, Nizar Habash, Benoît Sagot, et al.. CoNLL-UL: Universal Morphological Lattices for Universal Dependency Parsing. 11th Language Resources and Evaluation Conference, May 2018, Miyazaki, Japan. ⟨hal-01786125⟩
236 Consultations
326 Téléchargements
