Reports
A note on track-length sampling with non-exponential distributions
Abstract : Track-length sampling is the process of sampling random intervals according to a distance distribution. It means that, instead of sampling a punctual distance from the distance distribution, track-length sampling generates an interval of possible distances. The track-length sampling process is correct if the expectation of the intervals is the target distance distribution. In other words, averaging all the sampled intervals should converge towards the distance distribution as their number increases. In this note, we emphasize that the distance distribution that is used for sampling punctual distances and the track-length distribution that is used for sampling intervals are not the same in general. This difference can be surprising because, to our knowledge, track-length sampling has been mostly studied in the context of transport theory where the distance distribution is typically exponential: in this special case, the distance distribution and the track-length distribution happens to be both the same exponential distribution. However, they are not the same in general when the distance distribution is non-exponential. We show that track-length sampling can be used with non-exponential distance distributions if they are monotonically decreasing and we derive the general expression of the track-length distribution.
Document type :
Reports
Complete list of metadata
Cited literature [2 references]  Display  Hide  Download
https://hal.inria.fr/hal-01788593
Contributor : Eric Heitz <>
Submitted on : Wednesday, May 9, 2018 - 11:19:31 AM
Last modification on : Thursday, May 10, 2018 - 2:09:14 AM
Long-term archiving on: : Tuesday, September 25, 2018 - 8:07:09 AM
File
trackLength.pdf
Identifiers
  • HAL Id : hal-01788593, version 1
Collections
Citation
Eric Heitz, Laurent Belcour. A note on track-length sampling with non-exponential distributions. [Research Report] Unity Technologies. 2018. ⟨hal-01788593⟩
Share
Metrics
Record views
235
Files downloads
137
