Generalized Hermite Reduction, Creative Telescoping and Definite Integration of D-Finite Functions - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2018
Alin Bostan
  • Fonction : Auteur
  • PersonId : 831654
Pierre Lairez
Bruno Salvy
Hermite reduction is a classical algorithmic tool in symbolic integration. It is used to decompose a given rational function as a sum of a function with simple poles and the derivative of another rational function. We extend Hermite reduction to arbitrary linear differential operators instead of the pure derivative, and develop efficient algorithms for this reduction. We then apply the generalized Hermite reduction to the computation of linear operators satisfied by single definite integrals of D-finite functions of several continuous or discrete parameters. The resulting algorithm is a generalization of reduction-based methods for creative telescoping.
redct-final.pdf (770.86 Ko) Télécharger le fichier
hal-01788619 , version 1 (09-05-2018)
Alin Bostan, Frédéric Chyzak, Pierre Lairez, Bruno Salvy. Generalized Hermite Reduction, Creative Telescoping and Definite Integration of D-Finite Functions. ISSAC 2018 - International Symposium on Symbolic and Algebraic Computation, Jul 2018, New York, United States. pp.1-8, ⟨10.1145/3208976.3208992⟩. ⟨hal-01788619⟩
297 Consultations
198 Téléchargements
