Pharmacokinetics and Pharmacodynamics-Based Mathematical Modeling Identifies an Optimal Protocol for Metronomic Chemotherapy - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Cancer Research Année : 2017
Metronomic chemotherapy is usually associated with better tolerance than conventional chemotherapy, and encouraging response rates have been reported in various settings. However, clinical development of metronomic chemotherapy has been hampered by a number of limitations, including the vagueness of its definition and the resulting empiricism in protocol design. In this study, we developed a pharmacokinetic/pharmacodynam-ic mathematical model that identifies in silico the most effective administration schedule for gemcitabine monotherapy. This model is based upon four biological assumptions regarding the mechanisms of action of metronomic chemotherapy, resulting in a set of 6 minimally parameterized differential equations. Simulations identified daily 0.5–1 mg/kg gemcitabine as an optimal protocol to maximize antitumor efficacy. Both metronomic protocols (0.5 and 1 mg/kg/day for 28 days) were evaluated in chemoresistant neuroblastoma-bearing mice and compared with the standard MTD protocol (100 mg/kg once a week for 4 weeks). Systemic exposure to gemcitabine was 14 times lower in the metronomic groups compared with the standard group. Despite this, metronomic gemcitabine significantly inhibited tumor angiogenesis and reduced tumor perfusion and inflammation in vivo, while standard gemcitabine did not. Furthermore, met-ronomic gemcitabine yielded a 40%–50% decrease in tumor mass at the end of treatment as compared with control mice (P ¼ 0.002; ANOVA on ranks with Dunn test), while standard gemcitabine failed to significantly reduce tumor growth. Stable disease was maintained in the metronomic groups for up to 2 months after treatment completion (67%–72% reduction in tumor growth at study conclusion, P < 0.001; ANOVA on ranks with Dunn test). Collectively, our results confirmed the superiority of metronomic protocols in chemoresistant tumors in vivo.
hal-01789578 , version 1 (11-05-2018)
Joseph Ciccolini, Dominique Barbolosi, Christophe Meille, Cindy Serdjebi, Sarah Giacometti, et al.. Pharmacokinetics and Pharmacodynamics-Based Mathematical Modeling Identifies an Optimal Protocol for Metronomic Chemotherapy. Cancer Research, 2017, 77 (17), pp.4723-4733. ⟨10.1158/0008-5472.CAN-16-3130⟩. ⟨hal-01789578⟩
Collections
CNRS UNIV-AMU CRCM
36 Consultations
0 Téléchargements
