Hypersonic and high temperature gas dynamics, Mac Graw-Hill, 1989. ,
Ablative Thermal Protection Systems Modeling, AIAA Education Series, 2013. ,
Post-flight evaluation of stardust sample return capsule forebody heatshield material, pp.1-7, 2008. ,
Detailed chemical equilibrium model for porous ablative materials, International Journal of Heat and Mass Transfer, vol.90, pp.1034-1045, 2015. ,
Sizing and margins assessment of the mars science laboratory aeroshell thermal protection system, Journal of Spacecraft and Rockets, vol.51, issue.4, pp.1125-1138, 2014. ,
Monte carlo approach to fiat uncertainties with applications for mars science laboratory, Journal of Thermophysics and Heat Transfer, vol.25, pp.516-522, 2011. ,
A reliability comparison of classical and stochastic thickness margin approaches for the orion heat shield resulting from material property uncertainties ,
Quantitative determination of species production from the pyrolysis of a phenol-formaldehyde resin, Polymer Degradation and Stability, vol.112, pp.122-131, 2015. ,
Pyrolysis of phenolic impregnated carbon ablator (pica), Applied Materials and Interfaces, vol.3, issue.7, pp.1383-1395, 2015. ,
Detailed analysis of species production from the pyrolysis of phenolic impregnated carbon ablator, Journal of Analytical and Applied Pyrolysis, vol.122, pp.258-267, 2016. ,
Analyzing natural convection in porous enclosure with polynomial chaos expansions: Effect of thermal dispersion, anisotropic permeability and heterogeneity, International Journal of Heat and Mass Transfer, vol.115, pp.205-224, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01831148
Uncertainty analysis of laminar and turbulent aeroheating predictions for mars entry, International Journal of Heat and Mass Transfer, vol.112, pp.533-543, 2017. ,
Thermochemical ablation modeling forward uncertainty analysis-part i: Numerical methods and effect of model parameters, International Journal of Thermal Sciences, vol.118, pp.497-509, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01501225
Thermochemical ablation modeling forward uncertainty analysis-part ii: Application to plasma wind-tunnel testing, International Journal of Thermal Sciences, vol.118, pp.510-517, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01501226
Post-flight aerothermal analysis of the stardust sample return capsule, pp.1-15, 2008. ,
Ablation test-case series #2, version 2.8, 2011. ,
A generic local thermal equilibrium model for porous reactive materials submitted to high temperatures, International Journal of Heat and Mass Transfer, vol.108, pp.1406-1417, 2017. ,
Error analysis and estimation for the finite volume method with applications to fluid flows, 1996. ,
A tensorial approach to computational continuum mechanics using object-oriented techniques, Computers in physics, vol.12, issue.6, pp.620-631, 1998. ,
Porous material analysis toolbox based on openfoam and applications, Journal of Thermophysics and Heat Transfer, vol.28, issue.2, pp.191-202, 2014. ,
Code-to-code comparison, and material response modeling of Stardust and MSL using PATO and FIAT, NASA CR, vol.218960, pp.1-36, 2015. ,
An inverse parameter estimation methodology for the analysis of aeroheating and thermal protection system experimental data ,
Sensitivity measures, anova-like techniques and the use of bootstrap, Journal of Statistical Computation and Simulation, vol.58, pp.99-120, 1997. ,
Shape optimization of an airfoil in a bzt flow with multiple-source uncertainties, Computer Methods in Applied Mechanics and Engineering, vol.200, issue.1, pp.216-232, 2011. ,
URL : https://hal.archives-ouvertes.fr/inria-00549220
Sensitivity analysis using anchored anova expansion and high-order moments computation, International Journal for Numerical Methods in Engineering, vol.102, issue.9, pp.1554-1584, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-01086259
Adaptive {ANOVA} decomposition of stochastic incompressible and compressible flows, Journal of Computational Physics, vol.231, issue.4, pp.1587-1614, 2012. ,
The Wiener-Askey Polynomial Chaos for Stochastic Differential Equations, SIAM Journal on Scientific Computing, vol.24, issue.2, pp.619-644, 2002. ,
Polynomial chaos expansion for sensitivity analysis, Reliability engineering and system safety, vol.94, pp.1161-1172, 2009. ,
