Real-Time Parallel Hashing on the GPU, ACM Transactions on Graphics (Proceedings of ACM SIGGRAPH Asia, vol.28, p.5, 2009. ,
DOI : 10.1145/1661412.1618500
URL : http://www.cs.ucdavis.edu/~amenta/pubs/ParallelHash.pdf
Exact, robust, and efficient regularized Booleans on general 3D meshes, Computers & Mathematics with Applications, vol.70, issue.6, pp.1235-1254, 2015. ,
DOI : 10.1016/j.camwa.2015.06.016
URL : https://hal.archives-ouvertes.fr/hal-01203173
Slicing procedures for layered manufacturing techniques, Computer-Aided Design, vol.26, issue.2, pp.119-126, 1994. ,
DOI : 10.1016/0010-4485(94)90032-9
QuickCSG: Arbitrary and Faster Boolean Combinations of N Solids, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-01121419
Single-pass GPU Solid Voxelization for Real-time ApplicationsGI '08) Canadian Information Processing Society, Proceedings of Graphics Interface, pp.73-80, 2008. ,
Z-Buffer Rendering from CSG: The Trickle Algorithm, 1989. ,
Fast and accurate evaluation of regularized Boolean operations on triangulated solids, Computer-Aided Design, vol.45, issue.3, pp.705-716, 2013. ,
DOI : 10.1016/j.cad.2012.11.004
Coherent Parallel Hashing, ACM Transactions on Graphics, vol.30, issue.6, 2011. ,
An Introduction to Ray Tracing, 1989. ,
Near real-time CSG rendering using tree normalization and geometric pruning, IEEE Computer Graphics and Applications, vol.9, issue.3, pp.20-28, 1989. ,
DOI : 10.1109/38.28107
Blister, ACM Transactions on Graphics, vol.24, issue.3, pp.1024-1031, 2005. ,
DOI : 10.1145/1073204.1073306
Real-Time Shaded NC Milling Display, Proceedings of SIGGRAPH, pp.15-20, 1986. ,
Guaranteed ray intersections with implicit surfaces, ACM SIGGRAPH Computer Graphics, vol.23, issue.3, pp.297-306, 1989. ,
DOI : 10.1145/74334.74364
URL : http://www.cs.drexel.edu/~david/Classes/Papers/p297-kalra.pdf
Ray tracing CSG objects using single hit intersections, 2006. ,
IceSL: A GPU Accelerated CSG Modeler and Slicer. In AEFA'13, 18th European Forum on Additive Manufacturing, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-00926861
Per-Pixel Lists for Single Pass A-Buffer, In GPU Pro, vol.5, 2014. ,
DOI : 10.1201/b16721-3
URL : https://hal.archives-ouvertes.fr/hal-01093158
Memory-Efficient Order-Independent Transparency with Dynamic Fragment Buffer, Proc. 25th Conference on Graphics, Patterns and Images (SIBGRAPI, pp.134-141, 2012. ,
A survey of raster-based transparency techniques, Computers & Graphics, vol.35, issue.6, pp.1023-1034, 2011. ,
DOI : 10.1016/j.cag.2011.07.006
A survey of the marching cubes algorithm, Computers & Graphics, vol.30, issue.5, pp.854-879, 2006. ,
DOI : 10.1016/j.cag.2006.07.021
Deferred boundary evaluation of complex CSG models, Advances in Engineering Software, vol.85, pp.51-60, 2015. ,
DOI : 10.1016/j.advengsoft.2015.03.003
Procedural function-based modelling of volumetric microstructures, Graphical Models, vol.73, issue.5, pp.165-181, 2011. ,
DOI : 10.1016/j.gmod.2011.03.001
A constructive geometry for computer graphics, The Computer Journal, vol.16, issue.2, pp.157-160, 1973. ,
DOI : 10.1093/comjnl/16.2.157
Scalable GPU rendering of CSG models, Computers & Graphics, vol.32, issue.5, pp.526-539, 2008. ,
DOI : 10.1016/j.cag.2008.06.002
Ordered Boolean List (OBL): Reducing the Footprint for Evaluating Boolean Expressions, IEEE Transactions on Visualization and Computer Graphics, vol.17, issue.9, pp.1337-1351, 2011. ,
DOI : 10.1109/TVCG.2010.232
Blist: A Boolean list formulation of CSG trees, 1998. ,
Optimization principles and application performance evaluation of a multithreaded GPU using CUDA, Proceedings of the 13th ACM SIGPLAN Symposium on Principles and practice of parallel programming , PPoPP '08, pp.73-82, 2008. ,
DOI : 10.1145/1345206.1345220
Adaptive Mesh Booleans, 2016. ,
Fab forms, ACM Transactions on Graphics, vol.34, issue.4, 2015. ,
DOI : 10.1109/SMI.2005.25
URL : http://dspace.mit.edu/bitstream/1721.1/100914/1/fabforms_paper.pdf
An improved z-buffer CSG rendering algorithm, Proceedings of the ACM SIGGRAPH/EUROGRAPHICS workshop on Graphics hardware , HWWS '98, pp.25-30, 1998. ,
DOI : 10.1145/285305.285308
URL : http://www.nigels.com/research/egsggh98.pdf
Order-Independent Transparency using Per-Pixel Linked Lists, 2011. ,
DOI : 10.1201/b11325-34
Interactive vizualization of constructive solid geometry scenes on graphic processors, Programming and Computer Software, vol.8, issue.1, pp.258-267, 2017. ,
DOI : 10.1145/49155.51123
<inline-formula><tex-math notation="LaTeX">$k^+$</tex-math><alternatives> <inline-graphic xlink:type="simple" xlink:href="vasilakis-ieq1-2417581.gif"/></alternatives></inline-formula>-buffer: An Efficient, Memory-Friendly and Dynamic <inline-formula><tex-math notation="LaTeX">$k$</tex-math><alternatives> <inline-graphic xlink:type="simple" xlink:href="vasilakis-ieq2-2417581.gif"/></alternatives></inline-formula>-buffer Framework, IEEE Transactions on Visualization and Computer Graphics, vol.21, issue.6, pp.688-700, 2015. ,
DOI : 10.1109/TVCG.2015.2417581
OpenFab, ACM Transactions on Graphics, vol.32, issue.4, 2013. ,
DOI : 10.1145/2461912.2461993
Approximate Boolean Operations on Large Polyhedral Solids with Partial Mesh Reconstruction, IEEE Transactions on Visualization and Computer Graphics, vol.17, issue.6, pp.836-849, 2011. ,
An Efficient and Robust Ray-box Intersection Algorithm, ACM SIGGRAPH 2005 Courses (SIGGRAPH '05, 2005. ,
DOI : 10.1145/1198555.1198748
URL : http://cag.csail.mit.edu/~amy/papers/box-jgt.pdf
Extending the CSG Tree. Warping, Blending and Boolean Operations in an Implicit Surface Modeling System, Computer Graphics Forum, vol.18, issue.2, pp.149-158, 1999. ,
DOI : 10.1111/1467-8659.00365
Mesh arrangements for solid geometry, ACM Transactions on Graphics, vol.35, issue.4, 2016. ,
DOI : 10.1145/1057432.1057464
URL : http://dl.acm.org/ft_gateway.cfm?id=2925901&type=pdf
