Numerical analysis of the Half-Space Matching method with Robin traces on a convex polygonal scatterer - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Chapitre D'ouvrage Année : 2019
We consider the 2D Helmholtz equation with a complex wavenumber in the exterior of a convex polygonal obstacle, with a Robin type boundary condition. Using the principle of the Half-Space Matching method, the problem is formulated as a system of coupled Fourier-integral equations, the unknowns being the Robin traces on the infinite straight lines supported by the edges of the polygon. We prove that this system is a Fredholm equation of the second kind, in an $L^2$ functional framework. The truncation of the Fourier integrals and the finite element approximation of the corresponding numerical method are also analyzed. The theoretical results are supported by various numerical experiments.
HSMm_Robin.pdf (1.02 Mo) Télécharger le fichier
hal-01793511 , version 1 (16-05-2018)
hal-01793511 , version 2 (23-11-2018)
hal-01793511 , version 3 (05-12-2019)
  • HAL Id : hal-01793511 , version 3
Anne-Sophie Bonnet-Ben Dhia, Sonia Fliss, Yohanes Tjandrawidjaja. Numerical analysis of the Half-Space Matching method with Robin traces on a convex polygonal scatterer. Maxwell's equations: Analysis and numerics, 24, De Gruyter, 2019, Radon Series on Computational and Applied Mathematics. ⟨hal-01793511v3⟩
473 Consultations
434 Téléchargements
