Numerical analysis of the Half-Space Matching method with Robin traces on a convex polygonal scatterer
We consider the 2D Helmholtz equation with a complex wavenumber in the exterior of a convex polygonal obstacle, with a Robin type boundary condition. Using the principle of the Half-Space Matching method, the problem is formulated as a system of coupled Fourier-integral equations, the unknowns being the Robin traces on the infinite straight lines supported by the edges of the polygon. We prove that this system is a Fredholm equation of the second kind, in an $L^2$ functional framework. The truncation of the Fourier integrals and the finite element approximation of the corresponding numerical method are also analyzed. The theoretical results are supported by various numerical experiments.
