Multiplicity for ideals of maximal analytic spread and intersection theory, Journal of Mathematics of Kyoto University, vol.33, issue.4, pp.1029-1046, 1993. ,
DOI : 10.1215/kjm/1250519127
Geometry of the plane cremona maps, Lecture Notes in Mathematics, vol.1769, 2002. ,
DOI : 10.1007/b82933
Introduction to commutative algebra, 1969. ,
DOI : 10.1201/9780429493621
URL : http://users.rider.edu/~jmccullough/notes/IntroCommAlg.pdf
Effective criteria for bigraded birational maps, Journal of Symbolic Computation, vol.81, pp.69-87, 2017. ,
DOI : 10.1016/j.jsc.2016.12.001
URL : https://hal.archives-ouvertes.fr/hal-01278405
Local cohomology., Second An algebraic introduction with geometric applications, Cambridge Studies in Advanced Mathematics, vol.136 ,
Implicitizing rational hypersurfaces using approximation complexes, Journal of Symbolic Computation, vol.40, issue.4-5, pp.4-5, 2005. ,
DOI : 10.1016/j.jsc.2004.04.005
On the closed image of a rational map and the implicitization problem, Journal of Algebra, vol.265, issue.1, pp.312-357, 2003. ,
DOI : 10.1016/S0021-8693(03)00181-9
A D-module approach on the equations of the Rees algebra, 2017. ,
Syzygies and the Rees algebra, Journal of Pure and Applied Algebra, vol.212, issue.7, pp.1787-1796, 2008. ,
DOI : 10.1016/j.jpaa.2007.11.006
URL : https://doi.org/10.1016/j.jpaa.2007.11.006
Asymptotic behavior of the length of local cohomology, Canad, J. Math, vol.57, issue.6, pp.1178-1192, 2005. ,
Lectures on cremona transformations, 2016. ,
DOI : 10.1017/cbo9781139084437.008
A characteristic-free criterion of birationality, Advances in Mathematics, vol.230, issue.1, pp.390-413, 2012. ,
DOI : 10.1016/j.aim.2011.12.005
Commutative algebra with a view towards algebraic geometry, Graduate Texts in Mathematics, vol.150, 1995. ,
Row ideals and fibers of morphisms, Michigan Math, J, vol.57, pp.261-268, 2008. ,
DOI : 10.1307/mmj/1220879408
URL : http://arxiv.org/pdf/0705.3931
Joins and intersections, 1999. ,
DOI : 10.1007/978-3-662-03817-8_5
Intersection theory, Second, Ergebnisse der Mathematik und ihrer Grenzgebiete. 3. Folge. A Series of Modern Surveys in Mathematics, Mathematics and Related Areas. 3rd Series. A Series of Modern Surveys in Mathematics], 1998. ,
On graded rings, I, Journal of the Mathematical Society of Japan, vol.30, issue.2, pp.179-213, 1978. ,
DOI : 10.2969/jmsj/03020179
Macaulay2, a software system for research in algebraic geometry ,
EFFECTIVE CRITERIA FOR BIRATIONAL MORPHISMS, Journal of the London Mathematical Society, vol.67, issue.02, pp.337-348, 2003. ,
DOI : 10.1112/S002461070200385X
Algebraic geometry, Graduate Texts in Mathematics, vol.52, issue.52, 1977. ,
DOI : 10.1007/978-1-4757-3849-0
Plane Cremona maps: saturation and regularity of the base ideal, J. Algebra, vol.371, pp.620-652, 2012. ,
Approximation complexes of blowing-up rings, Journal of Algebra, vol.74, issue.2, pp.466-493, 1982. ,
DOI : 10.1016/0021-8693(82)90034-5
URL : https://doi.org/10.1016/0021-8693(82)90034-5
Curvilinear base points, local complete intersection and Koszul syzygies in biprojective spaces, Trans. Amer. Math. Soc, vol.358, issue.8, pp.3385-3398, 2006. ,
On the homology of two-dimensional elimination, Journal of Symbolic Computation, vol.43, issue.4, pp.275-292, 2008. ,
DOI : 10.1016/j.jsc.2007.10.010
Cremona transformations and syzygies, Mathematische Zeitschrift, vol.20, issue.1, pp.419-443, 1992. ,
DOI : 10.1007/3-540-09519-5_52
The diagonal subring and the Cohen-Macaulay property of a multigraded ring, Transactions of the American Mathematical Society, vol.351, issue.06, pp.2213-2232, 1999. ,
DOI : 10.1090/S0002-9947-99-02143-1
Multiplicities of classical varieties, Proceedings of the London Mathematical Society, vol.364, issue.(6), pp.1033-1055, 2015. ,
DOI : 10.1090/S0002-9947-2012-05434-1
Invariant Aspects of Elimination, Advances in Mathematics, vol.114, issue.1, pp.1-174, 1995. ,
DOI : 10.1006/aima.1995.1042
Commutative rings, Revised, 1974. ,
Rational normal scrolls and the defining equations of Rees algebras, Journal f??r die reine und angewandte Mathematik (Crelles Journal), vol.1, issue.650, pp.23-65, 2011. ,
DOI : 10.1016/j.jpaa.2004.12.043
The associated primes of local cohomology modules over rings of small dimension, manuscripta mathematica, vol.104, issue.4, pp.519-525, 2001. ,
DOI : 10.1007/s002290170024
Sur les algebres universelles, Annales de l'institut fourier, pp.33-87, 1964. ,
DOI : 10.5802/aif.173
Cremona transformations and special double structures, manuscripta mathematica, vol.52, issue.4, pp.491-510, 2005. ,
DOI : 10.1007/s00229-005-0573-2
Cremona maps of deJonquì eres type, Canad, J. Math, vol.67, issue.4, pp.923-941, 2015. ,
DOI : 10.4153/cjm-2014-037-3
URL : https://cms.math.ca/cjm/abstract/pdf/151219.pdf
On birational maps and Jacobian matrices, Compositio Mathematica, vol.126, issue.3, pp.335-358, 2001. ,
DOI : 10.1023/A:1017572213947
On the use of local cohomology in algebra and geometry, Six lectures on commutative algebra, Bellaterra, pp.241-292, 1996. ,
Birational 2D Free-Form Deformation of degree 1 ?? n, Computer Aided Geometric Design, vol.44, pp.1-9, 2016. ,
DOI : 10.1016/j.cagd.2016.02.020
Birational quadrilateral maps, Computer Aided Geometric Design, vol.32, pp.1-4, 2015. ,
Cremona transformations and some related algebras, Journal of Algebra, vol.280, issue.1, pp.162-179, 2004. ,
DOI : 10.1016/j.jalgebra.2004.03.025
URL : https://doi.org/10.1016/j.jalgebra.2004.03.025
Jacobian dual fibrations, Amer, 51] , Codimension, multiplicity and integral extensions, Math. Proc. Cambridge Philos, pp.47-75, 1993. ,
DOI : 10.2307/2374722
On the dimension and integrality of symmetric algebras, Mathematische Zeitschrift, vol.58, issue.3, pp.341-358, 1981. ,
DOI : 10.1007/BF01162067
Gröbner bases and convex polytopes, 1996. ,
DOI : 10.1090/ulect/008
On the equations of Rees algebras, J. Reine Angew. Math, vol.418, pp.189-218, 1991. ,
