Finite-time and fixed-time stabilization: Implicit Lyapunov function approach, Automatica, vol.51, pp.332-340, 2015. ,
DOI : 10.1016/j.automatica.2014.10.082
URL : https://hal.archives-ouvertes.fr/hal-01098099
Robust stabilization of MIMO systems in finite/fixed time, International Journal of Robust and Nonlinear Control, vol.42, issue.10, pp.69-90, 2016. ,
DOI : 10.1201/9781420065619
URL : https://hal.archives-ouvertes.fr/hal-01160052
Finite-Time Stability of Continuous Autonomous Systems, SIAM Journal on Control and Optimization, vol.38, issue.3, pp.751-766, 2000. ,
DOI : 10.1137/S0363012997321358
URL : http://www.aero.iitb.ac.in/~bhat/siam_fts.pdf
Finite Time Stability and Robust Control Synthesis of Uncertain Switched Systems, SIAM Journal on Control and Optimization, vol.43, issue.4, pp.1253-1271, 2004. ,
DOI : 10.1137/S0363012903425593
Predefinedtime stability of dynamical systems with sliding modes, American Control Conference (ACC), pp.5842-5846, 2015. ,
Stabilization of perturbed integrator chains using Lyapunov-Based Homogeneous Controllers, International Journal of Control, pp.1-10, 2016. ,
Homogeneous High Order Sliding Mode design: A Lyapunov approach, Automatica, vol.80, pp.232-238, 2017. ,
DOI : 10.1016/j.automatica.2017.02.039
Nonlinear Feedback Design for Fixed-Time Stabilization of Linear Control Systems, IEEE Transactions on Automatic Control, vol.57, issue.8, 2012. ,
DOI : 10.1109/TAC.2011.2179869
URL : https://hal.archives-ouvertes.fr/hal-00757561
Stabilization of chain of integrators with arbitrary order in finite-time, 2015 54th IEEE Conference on Decision and Control (CDC), pp.4637-4641, 2016. ,
DOI : 10.1109/CDC.2015.7402942
URL : https://hal.archives-ouvertes.fr/hal-01212600
Supervisory acceleration of convergence for homogeneous systems, International Journal of Control, vol.1, pp.1-11, 2017. ,
DOI : 10.1007/978-3-642-84379-2
URL : https://hal.archives-ouvertes.fr/hal-01411088
Accelerated High-Order MIMO Sliding Mode control, 2014 13th International Workshop on Variable Structure Systems (VSS), pp.1-6, 2014. ,
DOI : 10.1109/VSS.2014.6881095
Finite Time Stabilization of a Perturbed Double Integrator???Part I: Continuous Sliding Mode-Based Output Feedback Synthesis, IEEE Transactions on Automatic Control, vol.56, issue.3, pp.614-618, 2011. ,
DOI : 10.1109/TAC.2010.2090708
Robust finite-time output feedback control of perturbed double integrator, Automatica, vol.60, pp.86-91, 2015. ,
DOI : 10.1016/j.automatica.2015.07.008
Finite-time stabilization of uncertain triple integrator with only switch and gain, IECON 2011, 37th Annual Conference of the IEEE Industrial Electronics Society, pp.3942-3946, 2011. ,
DOI : 10.1109/IECON.2011.6119953
On a sign controller for the triple integrator, 52nd IEEE Conference on Decision and Control, pp.3566-3571, 2013. ,
DOI : 10.1109/CDC.2013.6760431
Lyapunov Functions and Stability in Control Theory, 2005. ,
On systems of ordinary differential equations with generalized homogenous right-hand sides, Izvestia vuzov, Mathematica, vol.1, pp.80-88, 1958. ,
Sliding mode control on electro-mechanical systems, Mathematical Problems in Engineering, vol.8, issue.4-5, 2009. ,
DOI : 10.1080/10241230306724
URL : http://doi.org/10.1080/10241230306724
Two approaches to hyperplane design in multivariable variable structure control systems, International Journal of Control, vol.129, issue.1, pp.65-82, 1986. ,
DOI : 10.1109/TAC.1977.1101661
Control of nonlinear dynamical systems: methods and applications, 2008. ,
DOI : 10.1007/978-3-540-70784-4
Differential equations with discontinuous right-hand side, 1988. ,
DOI : 10.1090/trans2/042/13
Robust exact uniformly convergent arbitrary order differentiator, Automatica, vol.49, issue.8, pp.2489-2495, 2013. ,
DOI : 10.1016/j.automatica.2013.04.034
