Unikernel-based Approach for Software-Defined Security in Cloud Infrastructures
The heterogeneity of cloud resources implies substantial overhead to deploy and configure adequate security mechanisms. In that context, we propose a software-defined security strategy based on unikernels to support the protection of cloud infrastructures. This approach permits to address management issues by uncoupling security policy from their enforcement through programmable security interfaces. It also takes benefits from unikernel virtualization properties to support this enforcement and provide resources with low attack surface. These resources correspond to highly constrained configurations with the strict minimum for a given period. We describe the management framework supporting this software-defined security strategy, formalizing the generation of unikernel images that are dynamically built to comply with security requirements over time. Through an implementation based on MirageOS, and extensive experiments, we show that the cost induced by our security integration mechanisms is small while the gains in limiting the security exposure are high.
