Transmission and Storage Rates for Sequential Massive Random Access - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2018
This paper introduces a new source coding paradigm called Sequential Massive Random Access (SMRA). In SMRA, a set of correlated sources is encoded once for all and stored on a server, and clients want to successively access to only a subset of the sources. Since the number of simultaneous clients can be huge, the server is only allowed to extract a bitstream from the stored data: no re-encoding can be performed before the transmission of the specific client's request. In this paper, we formally define the SMRA framework and introduce both storage and transmission rates to characterize the performance of SMRA. We derive achievable transmission and storage rates for lossless source coding of i.i.d. and non i.i.d. sources, and transmission and storage rates-distortion regions for Gaussian sources. We also show two practical implementations of SMRA systems based on rate-compatible LDPC codes. Both theoretical and experimental results demonstrate that SMRA systems can reach the same transmission rates as in traditional point to point source coding schemes, while having a reasonable overhead in terms of storage rate. These results constitute a breakthrough for many recent data transmission applications in which different parts of the data are requested by the clients.
1612.07163.pdf (1.24 Mo) Télécharger le fichier
hal-01799016 , version 1 (24-05-2018)
  • HAL Id : hal-01799016 , version 1
Elsa Dupraz, Thomas Maugey, Aline Roumy, Michel Kieffer. Transmission and Storage Rates for Sequential Massive Random Access. 2018. ⟨hal-01799016⟩
173 Consultations
65 Téléchargements
