An Alternative TAGE-like Conditional Branch Predictor - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue ACM Transactions on Architecture and Code Optimization Année : 2018
TAGE is one of the most accurate conditional branch predictors known today. However, TAGE does not exploit its input information perfectly, as it is possible to obtain significant prediction accuracy improvements by complementing TAGE with a statistical corrector using the same input information. This paper proposes an alternative TAGE-like predictor making statistical correction practically superfluous.
halbatage.pdf (391.42 Ko) Télécharger le fichier
hal-01799442 , version 1 (24-05-2018)
Pierre Michaud. An Alternative TAGE-like Conditional Branch Predictor. ACM Transactions on Architecture and Code Optimization, 2018, 15 (3), pp.1-24. ⟨10.1145/3226098⟩. ⟨hal-01799442⟩
927 Consultations
4697 Téléchargements
