On multiplicative transfer function approximation in the short-time Fourier transform domain, IEEE Signal Processing Letters, vol.14, issue.5, pp.337-340, 2007. ,
Signal enhancement using beamforming and nonstationarity with applications to speech, IEEE Transactions on Signal Processing, vol.49, issue.8, pp.1614-1626, 2001. ,
Estimation of relative transfer function in the presence of stationary noise based on segmental power spectral density matrix subtraction, IEEE International Conference on Acoustics, Speech and Signal Processing, pp.320-324, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-01119186
Van Trees, Detection, estimation, and modulation theory, 2004. ,
Blind separation of speech mixtures via time-frequency masking, IEEE Transactions on Signal Processing, vol.52, issue.7, pp.1830-1847, 2004. ,
Model-based expectationmaximization source separation and localization, IEEE Transactions on Audio, Speech, and Language Processing, vol.18, issue.2, pp.382-394, 2010. ,
MAP-based underdetermined blind source separation of convolutive mixtures by hierarchical clustering and 1-norm minimization, EURASIP Journal on Applied Signal Processing, issue.1, pp.81-81, 2007. ,
A consolidated perspective on multimicrophone speech enhancement and source separation, IEEE/ACM Transactions on Audio, Speech, and Language Processing, vol.25, issue.4, pp.692-730, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01414179
Beyond the narrowband approximation: Wideband convex methods for under-determined reverberant audio source separation, IEEE Transactions on Audio, Speech, and Language Processing, vol.18, issue.7, pp.1818-1829, 2010. ,
URL : https://hal.archives-ouvertes.fr/hal-00435897
Sparse reverberant audio source separation via reweighted analysis, IEEE Transactions on Audio, Speech, and Language Processing, vol.21, issue.7, pp.1391-1402, 2013. ,
Inverse filtering of room acoustics, IEEE Transactions on Acoustics, Speech, and Signal Processing, vol.36, issue.2, pp.145-152, 1988. ,
Multi-channel room impulse response shaping-a study, IEEE International Conference on Acoustics Speech and Signal Processing Proceedings (ICASSP), vol.5, pp.101-104, 2006. ,
Room impulse response shortening/reshaping with infinity-and p-norm optimization, IEEE Transactions on Audio, Speech, and Language Processing, vol.18, issue.2, pp.249-259, 2010. ,
Regularization for partial multichannel equalization for speech dereverberation, IEEE Transactions on Audio, Speech, and Language Processing, vol.21, issue.9, pp.1879-1890, 2013. ,
Joint dereverberation and noise reduction based on acoustic multi-channel equalization, IEEE/ACM Transactions on Audio, Speech, and Language Processing, vol.24, issue.4, pp.680-693, 2016. ,
Inverse filtering for speech dereverberation less sensitive to noise and room transfer function fluctuations, EURASIP Journal on Advances in Signal Processing, issue.1, pp.1-12, 2007. ,
DOI : 10.1155/2007/34013
URL : https://asp-eurasipjournals.springeropen.com/track/pdf/10.1155/2007/34013
A blind channel identification-based two-stage approach to separation and dereverberation of speech signals in a reverberant environment, IEEE Transactions on Speech and Audio Processing, vol.13, issue.5, pp.882-895, 2005. ,
Recovering of broadband reverberant speech signal by sub-band MINT method, IEEE International Conference on Acoustics, Speech, and Signal Processing (ICASSP), pp.969-972, 1991. ,
Realization of acoustic inverse filtering through multi-microphone sub-band processing, IEICE Transactions on Fundamentals of Electronics, vol.75, issue.11, pp.1474-1483, 1992. ,
Multichannel equalization in subbands, IEEE Workshop on Applications of Signal Processing to Audio and Acoustics, pp.203-206, 1999. ,
DOI : 10.1109/aspaa.1999.810885
URL : https://eprints.soton.ac.uk/251923/1/weiss99a.pdf
Equalization of multichannel acoustic systems in oversampled subbands, IEEE Transactions on Audio, Speech, and Language Processing, vol.17, issue.6, pp.1061-1070, 2009. ,
Robust speech dereverberation using subband multichannel least squares with variable relaxation, European Signal Processing Conference (EUSIPCO), 2013. ,
DOI : 10.1109/taslp.2014.2329632
System identification in the short-time Fourier transform domain with crossband filtering, IEEE Transactions on Audio, Speech, and Language Processing, vol.15, issue.4, pp.1305-1319, 2007. ,
Relative transfer function identification using convolutive transfer function approximation, IEEE Transactions on Audio, Speech, and Language Processing, vol.17, issue.4, pp.546-555, 2009. ,
DOI : 10.1109/tasl.2008.2009576
Convolutive transfer function generalized sidelobe canceler, IEEE transactions on audio, speech, and language processing, vol.17, pp.1420-1434, 2009. ,
DOI : 10.1109/tasl.2009.2020891
Estimation of the directpath relative transfer function for supervised sound-source localization, IEEE/ACM Transactions on Audio, Speech and Language Processing, vol.24, issue.11, pp.2171-2186, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01349691
Multiple-speaker localization based on direct-path features and likelihood maximization with spatial sparsity regularization, IEEE/ACM Transactions on Audio, Speech, and Language Processing, vol.25, issue.10, 1997. ,
DOI : 10.1109/taslp.2017.2740001
URL : https://hal.archives-ouvertes.fr/hal-01413417
Audio source separation based on convolutive transfer function and frequency-domain lasso optimization, IEEE International Conference on Acoustics, Speech, and Signal Processing, 2017. ,
DOI : 10.1109/icassp.2017.7952214
URL : https://hal.archives-ouvertes.fr/hal-01430754
Multichannel audio source separation: variational inference of time-frequency sources from timedomain observations, IEEE International Conference on Acoustics, Speech and Signal Processing, 2017. ,
DOI : 10.1109/icassp.2017.7951791
URL : https://hal.archives-ouvertes.fr/hal-01416347
Separating time-frequency sources from time-domain convolutive mixtures using non-negative matrix factorization, IEEE Workshop on Applications of Signal Processing to Audio and Acoustics (WASPAA), 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01548469
Multichannel high-resolution NMF for modeling convolutive mixtures of non-stationary signals in the timefrequency domain, IEEE/ACM Transactions on Audio, Speech, and Language Processing, vol.22, issue.11, pp.1670-1680, 2014. ,
Online speech dereverberation using kalman filter and EM algorithm, IEEE/ACM Transactions on Audio, Speech and Language Processing, vol.23, issue.2, pp.394-406, 2015. ,
DOI : 10.1109/taslp.2014.2372342
An EM algorithm for audio source separation based on the convolutive transfer function, IEEE Workshop on Applications of Signal Processing to Audio and Acoustics (WASPAA), 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01568818
A douglas-rachford splitting approach to nonsmooth convex variational signal recovery, IEEE Journal of Selected Topics in Signal Processing, vol.1, issue.4, pp.564-574, 2007. ,
URL : https://hal.archives-ouvertes.fr/hal-00621820
Signal recovery by proximal forwardbackward splitting, Multiscale Modeling & Simulation, vol.4, issue.4, pp.1168-1200, 2005. ,
DOI : 10.1137/050626090
URL : https://hal.archives-ouvertes.fr/hal-00017649
Speech distortion weighted multichannel wiener filtering techniques for noise reduction, pp.199-228, 2005. ,
Blind multichannel identification and equalization for dereverberation and noise reduction based on convolutive transfer function, CoRR, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01568835
Non-stationary noise power spectral density estimation based on regional statistics, IEEE International Conference on Acoustics, Speech and Signal Processing (ICASSP), pp.181-185, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01250892
Erlang distribution, Statistical Distributions, pp.84-85, 2010. ,
, Convex analysis, 2015.
Monotone operator splitting for optimization problems in sparse recovery, IEEE International Conference on Image Processing, pp.1461-1464, 2009. ,
URL : https://hal.archives-ouvertes.fr/hal-00813889
Gradient methods for minimizing composite objective function," tech. rep., International Association for Research and Teaching, 2007. ,
A fast iterative shrinkage-thresholding algorithm for linear inverse problems, SIAM journal on imaging sciences, vol.2, issue.1, pp.183-202, 2009. ,
Multichannel audio database in various acoustic environments, International Workshop on Acoustic Signal Enhancement, pp.313-317, 2014. ,
Getting started with the DARPA TIMIT CD-ROM: An acoustic phonetic continuous speech database, vol.107, 1988. ,
On the evaluation of estimated impulse responses, IEEE Signal processing letters, vol.5, issue.7, pp.174-176, 1998. ,
Performance measurement in blind audio source separation, IEEE transactions on audio, speech, and language processing, vol.14, pp.1462-1469, 2006. ,
URL : https://hal.archives-ouvertes.fr/inria-00544230
Perceptual evaluation of speech quality (PESQ)-a new method for speech quality assessment of telephone networks and codecs, IEEE International Conference on Acoustics, Speech, and Signal Processing, vol.2, pp.749-752, 2001. ,
An integrated real-time beamforming and postfiltering system for nonstationary noise environments, EURASIP Journal on Applied Signal Processing, pp.1064-1073, 2003. ,
Speech enhancement based on the general transfer function GSC and postfiltering, IEEE Transactions on Speech and Audio Processing, vol.12, issue.6, pp.561-571, 2004. ,
