Succinct: Enabling queries on compressed data, pp.337-350, 2015. ,
Integrating Online Compression to Accelerate Large-Scale Data Analytics Applications, 2013 IEEE 27th International Symposium on Parallel and Distributed Processing, pp.1205-1216, 2013. ,
DOI : 10.1109/IPDPS.2013.81
Location privacy for crowdsourcing applications, Proceedings of the 2016 ACM International Joint Conference on Pervasive and Ubiquitous Computing, UbiComp '16, pp.694-705, 2016. ,
DOI : 10.1145/1526709.1526816
Apache flink: Stream and batch processing in a single engine, p.28, 2015. ,
To compress or not to compress - compute vs. IO tradeoffs for mapreduce energy efficiency, Proceedings of the first ACM SIGCOMM workshop on Green networking, Green Networking '10, pp.23-28, 2010. ,
DOI : 10.1145/1851290.1851296
Benchmarking Streaming Computation Engines: Storm, Flink and Spark Streaming, 2016 IEEE International Parallel and Distributed Processing Symposium Workshops (IPDPSW), pp.1789-1792, 2016. ,
DOI : 10.1109/IPDPSW.2016.138
Adaptive Stream Processing using Dynamic Batch Sizing, Proceedings of the ACM Symposium on Cloud Computing, SOCC '14, pp.1-13, 2014. ,
DOI : 10.1007/978-1-4612-0577-7
URL : http://nma.berkeley.edu/ark:/28722/bk0015m4z46
Online unsupervised state recognition in sensor data, 2015 IEEE International Conference on Pervasive Computing and Communications (PerCom), pp.29-36, 2015. ,
DOI : 10.1109/PERCOM.2015.7146506
URL : https://infoscience.epfl.ch/record/204925/files/online_percom2015.pdf
Elastic scaling for data stream processing. Parallel and Distributed Systems, IEEE Transactions on, vol.25, issue.6, pp.1447-1463, 2014. ,
DOI : 10.1109/tpds.2013.295
URL : http://repository.bilkent.edu.tr/bitstream/11693/26675/1/Elastic%20scaling%20for%20data%20stream%20processing.pdf
Elf: efficient lightweight fast stream processing at scale, In: Usenix ATC, pp.25-36, 2014. ,
Lire: lucene image retrieval, Proceeding of the 16th ACM international conference on Multimedia, MM '08, pp.1085-1088, 2008. ,
DOI : 10.1145/1459359.1459577
Staying fit: Efficient load shedding techniques for distributed stream processing, pp.159-170, 2007. ,
Ernest: efficient performance prediction for large-scale advanced analytics, pp.363-378, 2016. ,
Druid, Proceedings of the 2014 ACM SIGMOD international conference on Management of data, SIGMOD '14, pp.157-168, 2014. ,
DOI : 10.1145/2588555.2595631
Elastic complex event processing exploiting prediction, 2015 IEEE International Conference on Big Data (Big Data), pp.213-222, 2015. ,
DOI : 10.1109/BigData.2015.7363758
Dynamic Load Balancing Techniques for Distributed Complex Event Processing Systems, In: DAIS, vol.23, issue.12, pp.174-188, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01434793
Discretized Streams: Fault Tolerant Streaming Computation at Scale Zip: https, SOSP, vol.22, pp.423-438, 2013. ,
