SENSE: Sensitivity encoding for fast MRI, Magnetic Resonance in Medicine, vol.30, issue.5, pp.952-962, 1999. ,
DOI : 10.1002/(SICI)1522-2594(199911)42:5<952::AID-MRM16>3.0.CO;2-S
Generalized autocalibrating partially parallel acquisitions (GRAPPA), Magnetic Resonance in Medicine, vol.41, issue.6, pp.1202-1210, 2002. ,
DOI : 10.1002/(SICI)1522-2594(199906)41:6<1236::AID-MRM21>3.0.CO;2-T
Compressed sensing, IEEE Transactions on Information Theory, vol.52, issue.4, pp.1289-1306, 2006. ,
DOI : 10.1109/TIT.2006.871582
URL : https://hal.archives-ouvertes.fr/inria-00369486
Robust uncertainty principles: exact signal reconstruction from highly incomplete frequency information, IEEE Transactions on Information Theory, vol.52, issue.2, pp.489-509, 2006. ,
DOI : 10.1109/TIT.2005.862083
Sparse MRI: The application of compressed sensing for rapid MR imaging, Magnetic Resonance in Medicine, vol.170, issue.6, pp.1182-1195, 2007. ,
DOI : 10.1002/mrm.21391
1 SPIRiT: Autocalibrating parallel imaging compressed sensing, Proc Intl Soc Mag Reson Med, p.379, 2009. ,
A rapid and robust numerical algorithm for sensitivity encoding with sparsity constraints: Self-feeding sparse SENSE, Magnetic Resonance in Medicine, vol.58, issue.4, pp.1078-1088, 2010. ,
DOI : 10.4310/CMS.2010.v8.n1.a6
A Fast Wavelet-Based Reconstruction Method for Magnetic Resonance Imaging, IEEE Transactions on Medical Imaging, vol.30, issue.9, pp.1649-1660, 2011. ,
DOI : 10.1109/TMI.2011.2140121
URL : https://hal.archives-ouvertes.fr/hal-01813870
, Comparisons of multiscale transforms: Reconstructed MR images from retrospectively under-sampled k-space noisy data using Sparkling sampling pattern (R = 2.4 and ISNR 30 dB) Top: Reference MR baboon image (left) and reconstructed image using Eq. (2) and Mallat WT. Center: MR images reconstructed image B-spline and Meyer WT. Bottom: MR images solutions computed using the analysis-based formulation and tight frames, Fig, vol.4
A wavelet-based regularized reconstruction algorithm for SENSE parallel MRI with applications to neuroimaging???, Medical Image Analysis, vol.15, issue.2, pp.185-201, 2011. ,
DOI : 10.1016/j.media.2010.08.001
URL : https://hal.archives-ouvertes.fr/hal-00692260
Spatio-temporal wavelet regularization for parallel MRI reconstruction: application to functional MRI, Magnetic Resonance Materials in Physics, Biology and Medicine, vol.1, issue.6, pp.509-529, 2014. ,
DOI : 10.1109/JSTSP.2007.910264
URL : https://hal.archives-ouvertes.fr/hal-01084324
Efficient Compressed Sensing SENSE pMRI Reconstruction With Joint Sparsity Promotion, IEEE Transactions on Medical Imaging, vol.35, issue.1, pp.354-368, 2016. ,
DOI : 10.1109/TMI.2015.2474383
A General Framework for Compressed Sensing and Parallel MRI Using Annihilating Filter Based Low-Rank Hankel Matrix, IEEE Transactions on Computational Imaging, vol.2, issue.4, pp.480-495, 2016. ,
DOI : 10.1109/TCI.2016.2601296
URL : http://bigwww.epfl.ch/publications/jin1601.pdf
Analysis versus synthesis in signal priors, Inverse Problems, vol.23, issue.3, p.947, 2007. ,
DOI : 10.1088/0266-5611/23/3/007
URL : http://www.cs.technion.ac.il/%7Eronrubin/Publications/eusipco_avs.pdf
Signal restoration with overcomplete wavelet transforms: comparison of analysis and synthesis priors, Wavelets XIII, p.74460, 2009. ,
DOI : 10.1117/12.826663
URL : http://www.lx.it.pt/~mtf/WaveletsXIII_SelesnickFigueiredo_2009.pdf
Compressed sensing MRI using discrete nonseparable shearlet transform and FISTA IEEE Sig. Fig. 5. Comparisons of under-sampling schemes (Radial, Sparkling) in the noise-free case. MR reconstructed images from retrospectively undersampled data (R = 2.4 in top row, R = 3.3 in bottom row) using the analysis-based formulation ,
DOI : 10.1109/lsp.2015.2414443
, Proc. Let, vol.22, issue.10, pp.1566-1570, 2015.
The curvelet transform for image denoising, IEEE Transactions on Image Processing, vol.11, issue.6, pp.670-684, 2002. ,
DOI : 10.1109/TIP.2002.1014998
Fast Discrete Curvelet Transforms, Multiscale Modeling & Simulation, vol.5, issue.3, pp.861-899, 2006. ,
DOI : 10.1137/05064182X
A splitting algorithm for dual monotone inclusions involving cocoercive operators, Adv. in Comput. Math, vol.38, issue.3, pp.667-681, 2013. ,
A Primal???Dual Splitting Method for Convex Optimization Involving Lipschitzian, Proximable and Linear Composite Terms, Journal of Optimization Theory and Applications, vol.23, issue.1???2, pp.460-479, 2013. ,
DOI : 10.1081/NFA-120003674
URL : https://hal.archives-ouvertes.fr/hal-00609728
Proximal splitting methods in signal processing, " in Fixed-point algorithms for inverse problems in science and engineering, pp.185-212, 2011. ,
A Fast Iterative Shrinkage-Thresholding Algorithm for Linear Inverse Problems, SIAM Journal on Imaging Sciences, vol.2, issue.1, pp.183-202, 2009. ,
DOI : 10.1137/080716542
ESPIRiT-an eigenvalue approach to autocalibrating parallel MRI: Where SENSE meets GRAPPA, Magnetic Resonance in Medicine, vol.43, issue.3, pp.990-1001, 2014. ,
DOI : 10.1002/(SICI)1522-2594(200005)43:5<682::AID-MRM10>3.0.CO;2-G
URL : http://europepmc.org/articles/pmc4142121?pdf=render
Self-calibrating nonlinear reconstruction algorithms for variable density sampling and parallel reception MRI, IEEE 10th Sensor Array and Multichannel Signal Processing workshop, 2018. ,
DOI : 10.1109/sam.2018.8448776
URL : https://hal.archives-ouvertes.fr/hal-01782428
Variable density compressed sensing in MRI. Theoretical vs heuristic sampling strategies, 2013 IEEE 10th International Symposium on Biomedical Imaging, pp.298-301, 2013. ,
DOI : 10.1109/ISBI.2013.6556471
URL : https://hal.archives-ouvertes.fr/hal-00848271
SPARKLING: Novel Non-Cartesian Sampling Schemes for Accelerated 2D Anatomical Imaging at 7T Using Compressed Sensing, 25th ISMRM conf, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01577200
On the Generation of Sampling Schemes for Magnetic Resonance Imaging, SIAM Journal on Imaging Sciences, vol.9, issue.4, pp.2039-2072, 2016. ,
DOI : 10.1137/16M1059205
URL : https://hal.archives-ouvertes.fr/hal-01373758
