Low power wide area machine-to-machine networks: key techniques and prototype, IEEE Communications Magazine, vol.53, issue.9, pp.64-71, 2015. ,
DOI : 10.1109/MCOM.2015.7263374
Latency Critical IoT Applications in 5G: Perspective on the Design of Radio Interface and Network Architecture, IEEE Communications Magazine, vol.55, issue.2, pp.70-78, 2017. ,
DOI : 10.1109/MCOM.2017.1600435CM
THE ALOHA SYSTEM, Proceedings of the November 17-19, 1970, fall joint computer conference on, AFIPS '70 (Fall), pp.281-285, 1970. ,
DOI : 10.1145/1478462.1478502
Stability properties of slotted Aloha with multipacket reception capability, IEEE Transactions on Automatic Control, vol.33, issue.7, pp.640-649, 1272. ,
DOI : 10.1109/9.1272
Massive Non-Orthogonal Multiple Access for Cellular IoT: Potentials and Limitations, IEEE Communications Magazine, vol.55, issue.9, 2017. ,
DOI : 10.1109/MCOM.2017.1600618
URL : http://arxiv.org/pdf/1612.00552
Robust uncertainty principles: exact signal reconstruction from highly incomplete frequency information, IEEE Transactions on Information Theory, vol.52, issue.2, 2006. ,
DOI : 10.1109/TIT.2005.862083
Compressive coded random access for massive MTC traffic in 5G systems, 2015 49th Asilomar Conference on Signals, Systems and Computers, pp.13-17, 2015. ,
DOI : 10.1109/ACSSC.2015.7421050
URL : http://arxiv.org/pdf/1707.00644
On-off random access channels: A compressed sensing framework, CoRR, 2009. ,
Orthogonal matching pursuit from noisy measurements: A new analysis Available: https://papers.nips.cc/paper/3784-orthogonal-matching- pursuit-from-noisy-random-measurements-a-new-analysis.pdf Many Access for Small Packets Based on Precoding and Sparsity-Aware Recovery, Proc. Neural Inf. Processing Syst. 22, pp.1-9, 2009. ,
Sparse code multiple access, 2013 IEEE 24th Annual International Symposium on Personal, Indoor, and Mobile Radio Communications (PIMRC), 2013. ,
DOI : 10.1109/PIMRC.2013.6666156
NOMA-Based Random Access With Multichannel ALOHA, IEEE Journal on Selected Areas in Communications, vol.35, issue.12, pp.2736-2743 ,
DOI : 10.1109/JSAC.2017.2766778
URL : http://arxiv.org/pdf/1706.08799
Signal Recovery From Random Measurements Via Orthogonal Matching Pursuit, IEEE Transactions on Information Theory, vol.53, issue.12, pp.4655-4666, 2007. ,
DOI : 10.1109/TIT.2007.909108
URL : https://authors.library.caltech.edu/9490/1/TROieeetit07.pdf
