Unsupervised Learning of Artistic Styles with Archetypal Style Analysis - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2018
In this paper, we introduce an unsupervised learning approach to automatically discover , summarize, and manipulate artistic styles from large collections of paintings. Our method is based on archetypal analysis, which is an unsupervised learning technique akin to sparse coding with a geometric interpretation. When applied to deep image representations from a collection of artworks, it learns a dictionary of archetypal styles, which can be easily visualized. After training the model, the style of a new image, which is characterized by local statistics of deep visual features, is approximated by a sparse convex combination of archetypes. This enables us to interpret which archetypal styles are present in the input image, and in which proportion. Finally, our approach allows us to manipulate the coefficients of the latent archetypal decomposition, and achieve various special effects such as style enhancement, transfer, and interpolation between multiple archetypes.
archetypal_style.pdf (9.5 Mo) Télécharger le fichier
hal-01802131 , version 1 (29-05-2018)
hal-01802131 , version 2 (03-10-2018)
  • HAL Id : hal-01802131 , version 2
Daan Wynen, Cordelia Schmid, Julien Mairal. Unsupervised Learning of Artistic Styles with Archetypal Style Analysis. NeurIPS 2018 - Annual Conference on Neural Information Processing Systems, Dec 2018, Montréal, Canada. pp.1-10. ⟨hal-01802131v2⟩
624 Consultations
2126 Téléchargements
