Solving 2D linear isotropic elastodynamics by means of scalar potentials: a new challenge for finite elements - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Scientific Computing Année : 2018
In this work we present a method for the computation of numerical solutions of 2D homogeneous isotropic elastodynamics equations by solving scalar wave equations. These equations act on the potentials of a Helmholtz decomposition of the displacement field and are decoupled inside the propagation domain. We detail how these equations are coupled at the boundary depending on the nature of the boundary condition satisfied by the displacement field. After presenting the case of rigid boundary conditions, that presents no specific difficulty, we tackle the challenging case of free surface boundary conditions that presents severe stability issues if a straightforward approach is used. We introduce an adequate functional framework as well as a time domain mixed formulation to circumvent these issues. Numerical results confirm the stability of the proposed approach.
ElastoPot_PJ.pdf (3.14 Mo) Télécharger le fichier
hal-01803536 , version 1 (30-05-2018)
Jorge Albella Martínez, Sébastien Imperiale, Patrick Joly, Jerónimo Rodríguez. Solving 2D linear isotropic elastodynamics by means of scalar potentials: a new challenge for finite elements. Journal of Scientific Computing, 2018, ⟨10.1007/s10915-018-0768-9⟩. ⟨hal-01803536⟩
391 Consultations
710 Téléchargements
