Service interruption on Monday 11 July from 12:30 to 13:00: all the sites of the CCSD (HAL, Epiciences, SciencesConf, AureHAL) will be inaccessible (network hardware connection).
Conference papers
Adaptive Mesh Refinement Method Applied to Shallow Water Model: A Mass Conservative Projection
Abstract : In the tsunami waves context, efficient numerical methods are necessary to simulate multiscales events. One way to reduce the computational cost is to use an adaptive mesh refinement method on unstructured meshes. This approach is used in this paper with a finite volume scheme solving the multi-dimensional Saint-Venant system. The adaptive mesh refinement method follows a block-based decomposition (called BB-AMR), which allows quick meshing and easy parallelization. One step of the AMR method is the so-called projection step where the new mesh values have to be defined from the old ones. For vertically integrated model the bathymetry variation during the projection step plays a crucial role on the mass conservation. To avoid large deficit or excess of mass a special attention is given to the projection step. Finally a 3D test case simulation is compared to experimental results to illustrated the quasi conservation of the mass with an appropriated projection method.
Document type :
Conference papers
Complete list of metadata
https://hal.inria.fr/hal-01805238
Contributor : Frederic Golay Connect in order to contact the contributor
Submitted on : Friday, December 10, 2021 - 11:39:40 AM
Last modification on : Friday, December 10, 2021 - 1:45:59 PM
Long-term archiving on: : Friday, March 11, 2022 - 6:57:28 PM
File
proc_2017_TPFD_Prague.pdf
Identifiers
Collections
Citation
Kévin Pons, Frederic Golay, R. Marcer. Adaptive Mesh Refinement Method Applied to Shallow Water Model: A Mass Conservative Projection. Topical Problems of Fluid Mechanics 2017, Feb 2017, Prague, Czech Republic. ⟨10.14311/TPFM.2017.032⟩. ⟨hal-01805238⟩
Share
Metrics
Record views
95
Files downloads
14
