Abstract : The Abella theorem prover is based on a logic in which relations, and not functions, are defined by induction (and coinduction). Of course, many relations do, in fact, define functions and there is real value in separating functional computation (marked by determinism) from more general deduction (marked by nondeterminism and backtracking). Recent work on focused proof systems for the logic underlying Abella is used in this paper to motivate the design of various extensions to the Abella system. With these extensions to the system (which do not extend the logic), it is possible to fully automate functional computations within the relational setting as soon as a proof is provided that a given relation does, in fact, capture a total function. In this way, we can use Abella to compute functions even when data structures contain bindings.
