Reference-based stochastic subspace identification for output-only modal analysis, Mechanical systems and signal processing, pp.855-878, 1999. ,
Input/output versus output-only data processing for structural identification???Application to in-flight data analysis, Journal of Sound and Vibration, vol.295, issue.3-5, pp.531-552, 2006. ,
DOI : 10.1016/j.jsv.2006.01.039
Propagator-based methods for recursive subspace model identification, Signal Processing, vol.88, issue.3, pp.468-491, 2008. ,
DOI : 10.1016/j.sigpro.2007.09.012
Recursive output-only subspace identification for in-flight flutter monitoring, Proceedings of the 22nd International Modal Analysis Conference (IMACXXII), 2004. ,
Recursive subspace identification based on instrumental variable unconstrained quadratic optimization, International Journal of Adaptive Control and Signal Processing, vol.34, issue.6, pp.9-10, 2004. ,
DOI : 10.1109/9.24243
URL : https://hal.archives-ouvertes.fr/hal-00098154
A non-iterative structural damage identification methodology using state space eigenstructure assignment, Structure and Infrastructure Engineering, vol.10, issue.2, pp.211-222, 2017. ,
DOI : 10.2514/3.11146
Non-iterative eigenstructure assignment technique for finite element model updating, Journal of Civil Structural Health Monitoring, vol.28, issue.9, pp.365-375, 2015. ,
DOI : 10.2514/3.25267
Structural Identification by Extended Kalman Filter, Journal of Engineering Mechanics, vol.110, issue.12, pp.1757-1770, 1984. ,
DOI : 10.1061/(ASCE)0733-9399(1984)110:12(1757)
Structural-System Identification. I: Theory, Journal of Engineering Mechanics, vol.121, issue.2, pp.255-264, 1995. ,
DOI : 10.1061/(ASCE)0733-9399(1995)121:2(255)
System identification of an experimental model by extended kalman filter, Structural Safety and Reliability: ICOSSAR'01, 2001. ,
Nonlinear dynamic state estimation in instrumented structures with conditionally linear gaussian substructures, Probabilistic Engineering Mechanics, vol.30, pp.89-103, 2012. ,
Updating response sensitivity models of nonlinear vibrating structures using particle filters, Computers & Structures, vol.89, issue.11-12, pp.901-911, 2011. ,
DOI : 10.1016/j.compstruc.2011.02.008
Particle filters for structural system identification using multiple test and sensor data: A combined computational and experimental study, Structural Control and Health Monitoring, vol.46, issue.2, pp.99-120, 2011. ,
DOI : 10.1887/0750303565
New extension of the Kalman filter to nonlinear systems, Signal Processing, Sensor Fusion, and Target Recognition VI, pp.182-193, 1997. ,
DOI : 10.1117/12.280797
URL : http://varsha.ece.ogi.edu/~rvdmerwe/docs/papers/./UT/Julier_AeroSense_97.ps.gz
Unscented Kalman filtering for nonlinear structural dynamics, Nonlinear Dynamics, vol.77, issue.1-2, pp.131-150, 2007. ,
DOI : 10.1007/978-3-642-18255-6
Bayesian state and parameter estimation of uncertain dynamical systems, Probabilistic engineering mechanics, pp.81-96, 2006. ,
DOI : 10.1016/j.probengmech.2005.08.003
The unscented kalman filter and particle filter methods for nonlinear structural system identification with non-collocated heterogeneous sensing, Structural control and health monitoring, pp.99-123, 2009. ,
DOI : 10.1002/stc.290
Stochastic system identification via particle and sigma-point Kalman filtering, Scientia Iranica, vol.19, issue.4, pp.982-991, 2012. ,
DOI : 10.1016/j.scient.2012.06.007
Obstacles to High-Dimensional Particle Filtering, Monthly Weather Review, vol.136, issue.12, pp.4629-4640, 2008. ,
DOI : 10.1175/2008MWR2529.1
URL : http://www.stat.berkeley.edu/~bickel/SBBA2008_submitted.pdf
Novel Unscented Kalman Filter for Health Assessment of Structural Systems with Unknown Input, Journal of Engineering Mechanics, vol.141, issue.7, p.4015012, 2015. ,
DOI : 10.1061/(ASCE)EM.1943-7889.0000926
Unscented Kalman filter with unknown input and weighted global iteration for health assessment of large structural systems, Structural Control and Health Monitoring, vol.30, issue.1, pp.156-175, 2016. ,
Parameter identification in explicit structural dynamics: performance of the extended Kalman filter, Computer Methods in Applied Mechanics and Engineering, vol.193, issue.36-38, pp.3807-3835, 2004. ,
DOI : 10.1016/j.cma.2004.02.003
Rao-blackwellised particle filtering for dynamic bayesian networks, Proceedings of the Sixteenth conference on Uncertainty in artificial intelligence, pp.176-183, 2000. ,
Estimation of parameters in a linear state space model using a Rao-Blackwellised particle filter, IEE Proceedings - Control Theory and Applications, vol.151, issue.6, pp.727-738, 2004. ,
DOI : 10.1049/ip-cta:20041008
Formulae, genealogical and interacting particle systems with applications, probability and its applications, 2004. ,
Bayesian filtering: From kalman filters to particle filters, and beyond, Statistics, vol.182, issue.1, pp.1-69, 2003. ,
Damage Detection in Flexible Plates through Reduced-Order Modeling and Hybrid Particle-Kalman Filtering, Sensors, vol.40, issue.1, 2015. ,
DOI : 10.1109/TAES.2004.1337485
URL : http://www.mdpi.com/1424-8220/16/1/2/pdf
Progressive damage identification using dual extended Kalman filter, Acta Mechanica, vol.47, issue.3, pp.2099-2109, 2016. ,
DOI : 10.12989/sem.2013.47.3.361
Online structural damage identification technique using constrained dual extended kalman filter, Structural Control and Health Monitoring ,
DOI : 10.1002/stc.1961
Parallelized sigma-point kalman filtering for structural dynamics, Computers & Structures, vol.92, pp.193-205, 2012. ,
A dual kalman filter approach for state estimation via output-only acceleration measurements, Mechanical Systems and Signal Processing, vol.60, pp.866-886, 2015. ,
Asymptotic behavior of the extended Kalman filter as a parameter estimator for linear systems, IEEE Transactions on Automatic Control, vol.24, issue.1, pp.36-50, 1979. ,
DOI : 10.1109/TAC.1979.1101943
Modal parameter estimation using interacting Kalman filter, Mechanical Systems and Signal Processing, vol.47, issue.1-2, pp.139-150, 2014. ,
DOI : 10.1016/j.ymssp.2012.11.005
URL : https://hal.archives-ouvertes.fr/hal-00824108
Gpgpu implementation of modal meter tracking by particle based kalman filter, 8th European Workshop On Structural Health Monitoring, p.2016, 2016. ,
Unbiased minimum-variance linear state estimation, Automatica, vol.23, issue.6, pp.775-778, 1987. ,
DOI : 10.1016/0005-1098(87)90037-9
Robust two-stage Kalman filters for systems with unknown inputs, IEEE Transactions on Automatic Control, vol.45, issue.12, pp.2374-2378, 2000. ,
DOI : 10.1109/9.895577
Unbiased minimum-variance input and state estimation for linear discrete-time systems, Automatica, vol.43, issue.1, pp.111-116, 2007. ,
DOI : 10.1016/j.automatica.2006.08.002
Unbiased minimum-variance input and state estimation for linear discrete-time systems with direct feedthrough, Automatica, vol.43, issue.5, pp.934-937, 2007. ,
DOI : 10.1016/j.automatica.2006.11.016
Joint input-response estimation for structural systems based on reduced-order models and vibration data from a limited number of sensors, Mechanical Systems and Signal Processing, vol.29, pp.310-327, 2012. ,
DOI : 10.1016/j.ymssp.2012.01.011
An augmented Kalman filter for force identification in structural dynamics, Mechanical Systems and Signal Processing, vol.27, pp.446-460, 2012. ,
DOI : 10.1016/j.ymssp.2011.09.025
Bayesian nonlinear structural FE model and seismic input identification for damage assessment of civil structures, Mechanical Systems and Signal Processing, vol.93, pp.661-687, 2017. ,
DOI : 10.1016/j.ymssp.2017.01.040
An online coupled state/input/parameter estimation approach for structural dynamics, Computer Methods in Applied Mechanics and Engineering, vol.283, pp.1167-1188, 2015. ,
DOI : 10.1016/j.cma.2014.08.010
OUTPUT???ONLY SCHEMES FOR JOINT INPUT???STATE???PARAMETER ESTIMATION OF LINEAR SYSTEMS, Proceedings of the 1st International Conference on Uncertainty Quantification in Computational Sciences and Engineering (UNCECOMP 2015), pp.497-510, 2015. ,
DOI : 10.7712/120215.4288.753
Reference-based combined deterministic???stochastic subspace identification for experimental and operational modal analysis, Mechanical Systems and Signal Processing, vol.22, issue.3, pp.617-637, 2008. ,
DOI : 10.1016/j.ymssp.2007.09.004
Subspace identification for linear systemskluwer academic publishers, pp.978-0792397175, 1996. ,
Joint input-state estimation in structural dynamics, Mechanical Systems and Signal Processing, vol.70, issue.71, pp.445-466, 2016. ,
DOI : 10.1016/j.ymssp.2015.07.025
An introduction to the kalman filter, Proc of SIGGRAPH, 2001. ,
Combined Parameter and State Estimation in Simulation-Based Filtering, pp.197-223, 2001. ,
DOI : 10.1007/978-1-4757-3437-9_10
Approximating posterior distributions by mixture, Journal of the Royal Statistical Society. Series B (Methodological ), pp.409-422, 1993. ,
Mixture models, monte carlo, bayesian updating, and dynamic models, Computing Science and Statistics, pp.325-325, 1993. ,
Particle filters for positioning, navigation, and tracking, IEEE Transactions on Signal Processing, vol.50, issue.2, pp.425-437, 2002. ,
DOI : 10.1109/78.978396
URL : http://www.control.isy.liu.se/~fredrik/reports/01SPpf4pos.pdf
Critical Assessment of Interstory Drift Measurements, Journal of Structural Engineering, vol.136, issue.12, pp.1574-1584, 2010. ,
DOI : 10.1061/(ASCE)ST.1943-541X.0000255
