, Data Never Sleeps
, Apache Spark Streaming Project
Apache flink: Stream and batch processing in a single engine, Bulletin of the IEEE Computer Society Technical Committee on Data Engineering, vol.36, issue.4, 2015. ,
, Proceedings of the 2014 ACM SIGMOD International Conference on Management of Data, ser. SIGMOD'14, pp.147-156, 2014.
Twitter heron: Stream processing at scale, Proceedings of the 2015 ACM SIGMOD International Conference on Management of Data, ser. SIGMOD'15, pp.239-250, 2015. ,
, Alibaba JStorm Project
, JStorm in Alibaba
Rstorm: Resource-aware scheduling in storm, Proceedings of the 16th ACM/IFIP/USENIX International Conference on Middleware, ser. Middleware'15, pp.149-161, 2015. ,
Network-aware operator placement for stream-processing systems, Proceedings of the 22nd International Conference on Data Engineering, ser. ICDE'06, pp.49-49, 2006. ,
Soda: An optimizing scheduler for large-scale stream-based distributed computer systems, Proceedings of the 9th ACM/IFIP/USENIX International Conference on Middleware, ser. Middleware'08, pp.306-325, 2008. ,
Runtime-aware adaptive scheduling in stream processing, Concurrency and Computation: Practice and Experience, vol.28, issue.14, pp.3830-3843, 2016. ,
T-storm: Traffic-aware online scheduling in storm, Proceedings of the 2014 IEEE 34th International Conference on Distributed Computing Systems, ser. ICDCS'14, pp.535-544, 2014. ,
Cache-efficient, intranode, large-message MPI communication with MPICH2-Nemesis, Proceedings of the 2009 International Conference on Parallel Processing, ser. ICPP'09, pp.462-469, 2009. ,
URL : https://hal.archives-ouvertes.fr/inria-00390064
Limic: Support for high-performance MPI intra-node communication on linux cluster, Proceedings of the 2005 International Conference on Parallel Processing, ser. ICPP'05, pp.184-191, 2005. ,
Locality and topology aware intra-node communication among multicore CPUs, Recent Advances in the Message Passing Interface, pp.265-274, 2010. ,
, Yahoo Streaming Benchmarks
Smooth task migration in apache storm, Proceedings of the 2015 ACM SIGMOD International Conference on Management of Data, ser. SIGMOD'15, pp.2067-2068, 2015. ,
Adaptive online scheduling in storm, Proceedings of the 7th ACM International Conference on Distributed Event-based Systems, ser. DEBS'13, pp.207-218, 2013. ,
Lock-free linked lists using compare-and-swap, Proceedings of the Fourteenth Annual ACM Symposium on Principles of Distributed Computing, pp.214-222, 1995. ,
Elastic scaling of data parallel operators in stream processing, Proceedings of the 2009 IEEE International Symposium on Parallel&Distributed Processing, ser. IPDPS'09, pp.1-12, 2009. ,
Integrating scale out and fault tolerance in stream processing using operator state management, Proceedings of the 2013 ACM SIGMOD International Conference on Management of Data, ser. SIGMOD'13, pp.725-736, 2013. ,
Making state explicit for imperative big data processing, Proceedings of the 2014 USENIX Conference on USENIX Annual Technical Conference, ser. USENIX ATC'14, pp.49-60, 2014. ,
Latencyaware elastic scaling for distributed data stream processing systems, Proceedings of the 8th ACM International Conference on Distributed Event-Based Systems, ser. DEBS'14, pp.13-22, 2014. ,
, Storm Throughput Test
, Apache Hadoop Project
High performance RDMA-based design of HDFS over infiniband, Proceedings of the 2012 International Conference for High Performance Computing, Networking, Storage and Analysis, ser. SC'12, pp.1-12, 2012. ,
JVM-bypass for efficient hadoop shuffling, Proceedings of 2013 IEEE 27th International Symposium on Parallel and Distributed Processing, pp.569-578, 2013. ,
Design and evaluation of nemesis, a scalable, low-latency, message-passing communication subsystem, Proceedings of the Sixth IEEE International Symposium on Cluster Computing and the Grid, ser. CCGRID'06 ,
URL : https://hal.archives-ouvertes.fr/hal-00344350
, , pp.521-530, 2006.
A high-performance, portable implementation of the MPI message passing interface standard, Parallel Computing, vol.22, issue.6, pp.789-828, 1996. ,
Online scheduling and interference alleviation for low-latency, highthroughput processing of data streams, IEEE Transactions on Parallel and Distributed Systems, vol.28, issue.12, pp.3553-3569, 2017. ,
Adastorm: Resource efficient storm with adaptive configuration, Proceedings of 2017 IEEE 33rd International Conference on Data Engineering (ICDE), pp.1363-1364, 2017. ,
