A Globally Convergent Adaptive Indirect Field-Oriented Torque Controller for Induction Motors - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Asian Journal of Control Année : 2020
One of the most challenging problems in AC drives applications is the design of a simple plug-in adaptation scheme to estimate the unknown rotor resistance and load torque for the industry-standard indirect field oriented control. In this paper we give the first globally convergent solution to this problem for torque control of current-fed induction motors that does not rely on any excitation assumption. Some results on speed regulation are also presented.
_AJC_HAL.pdf (591.12 Ko) Télécharger le fichier
hal-01807720 , version 1 (18-06-2018)
Romeo Ortega, Anton Pyrkin, Alexey Bobtsov, Denis Efimov, Stanislav Aranovskiy. A Globally Convergent Adaptive Indirect Field-Oriented Torque Controller for Induction Motors. Asian Journal of Control, 2020, 22 (1), pp.11-24. ⟨10.1002/asjc.1904⟩. ⟨hal-01807720⟩
414 Consultations
286 Téléchargements
