An Overview of in Silico Methods for the Prediction of Ionizing Radiation Resistance in Bacteria - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Chapitre D'ouvrage Année : 2018
Ionizing-radiation-resistant bacteria (IRRB) could be used for biore-mediation of radioactive wastes and in the therapeutic industry. Limited computational works are available for the prediction of bacterial ionizing radiation resistance (IRR). In this chapter, we present some works that study the causes of the high resistance of IRRB to ionizing radiation. Then we focus on presenting in silico approaches that use protein sequences of bacteria in order to predict if an unknown bacterium belongs to IRRB or ionizing-radiation-sensitive bacteria (IRSB). These approaches formulate the problem of predicting bacterial IRR as a multiple instance learning (MIL) problem where bacteria represent the bags and * Corresponding Author: manel.zoghlami@gmail.com. 2 Manel Zoghlami, Sabeur Aridhi, Mondher Maddouri et al. primary structure of basal DNA repair proteins of each bacterium represent the instances inside the bags. We also present a formulation of the problem of MIL in sequence data and explain how it could be used to solve the problem of IRR prediction in bacteria. A brief comparison of the presented approaches is provided.
Zoghlami et al Chapter - Nova.pdf (146.09 Ko) Télécharger le fichier
hal-01807944 , version 1 (20-06-2018)
  • HAL Id : hal-01807944 , version 1
Manel Zoghlami, Sabeur Aridhi, Mondher Maddouri, Engelbert Mephu Nguifo. An Overview of in Silico Methods for the Prediction of Ionizing Radiation Resistance in Bacteria. Tamar Reeve. Ionizing Radiation: Advances in Research and Applications, Nova science publishers, pp.241-256, 2018, Physics Research and Technology Series, 978-1-53613-539-8. ⟨hal-01807944⟩
245 Consultations
99 Téléchargements
