Synaptic plasticity: taming the beast, Nat. Neurosci, vol.3, 1124. ,
Differential Tonic GABA Conductances in Striatal Medium Spiny Neurons, Journal of Neuroscience, vol.28, issue.5, pp.1185-1197, 2008. ,
DOI : 10.1523/JNEUROSCI.3908-07.2008
URL : http://www.jneurosci.org/content/jneuro/28/5/1185.full.pdf
Long-term depression of inhibitory synaptic transmission induced by spike-timing dependent plasticity requires coactivation of endocannabinoid and muscarinic receptors, Hippocampus, vol.31, issue.Part 1, pp.1439-1452, 2013. ,
DOI : 10.1523/JNEUROSCI.5303-10.2011
Gliotransmitters Travel in Time and Space, Neuron, vol.81, issue.4, pp.728-739, 2014. ,
DOI : 10.1016/j.neuron.2014.02.007
URL : https://doi.org/10.1016/j.neuron.2014.02.007
Adenosine Shifts 1142 Plasticity Regimes between Associative and Homeostatic by Modulating Heterosynaptic 1143, 2017. ,
DOI : 10.1523/jneurosci.2984-16.2016
URL : http://www.jneurosci.org/content/jneuro/37/6/1439.full.pdf
The role of dendritic inhibition in shaping the plasticity of https, 2013. ,
The role of kinetic context in apparent biased agonism at GPCRs, Nat. Commun, vol.710, 1038. ,
Calcium dynamics in single spines during coincident pre- and 1393 postsynaptic activity depend on relative timing of back-propagating action potentials and 1394 subthreshold excitatory postsynaptic potentials, Proc. Natl. Acad. Sci. U. S. A. 95, p.9596, 1998. ,
DOI : 10.1073/pnas.95.16.9596
URL : http://www.pnas.org/content/95/16/9596.full.pdf
Frequency-Dependent Changes in NMDAR-Dependent Synaptic Plasticity, Frontiers in Computational Neuroscience, vol.5, 1398. ,
DOI : 10.3389/fncom.2011.00038
URL : https://www.frontiersin.org/articles/10.3389/fncom.2011.00038/pdf
Learning with three factors: modulating Hebbian plasticity with errors, Current Opinion in Neurobiology, vol.46, pp.170-177, 2017. ,
DOI : 10.1016/j.conb.2017.08.020
Endocannabinoid signaling mediates 1403 psychomotor activation by adenosine A2A antagonists, J. Neurosci. Off. J. Soc. Neurosci, vol.30, 2010. ,
DOI : 10.1523/jneurosci.5844-09.2010
URL : http://www.jneurosci.org/content/jneuro/30/6/2160.full.pdf
Input-Timing-Dependent Plasticity in the 1406, 2017. ,
Learning Rules for Spike Timing-Dependent, 1410. ,
A Synaptically Controlled, Associative Signal for Hebbian Plasticity in Hippocampal Neurons, Science, vol.275, issue.5297, pp.209-213, 1997. ,
DOI : 10.1126/science.275.5297.209
Naturalistic stimulation drives opposing heterosynaptic plasticity at two inputs to songbird cortex, Nature Neuroscience, vol.20, issue.9, pp.1272-1280, 2015. ,
DOI : 10.1152/jn.00977.2009
URL : http://europepmc.org/articles/pmc5726397?pdf=render
Calcium messenger heterogeneity: a possible signal for spike timing- 1439 dependent plasticity, Front. Comput. Neurosci, vol.4, issue.158, 1440. ,
DOI : 10.3389/fncom.2010.00158
URL : http://journal.frontiersin.org/article/10.3389/fncom.2010.00158/pdf
Astrocyte signaling controls spike timing???dependent depression at neocortical synapses, Nature Neuroscience, vol.15, issue.5, pp.746-753, 2012. ,
DOI : 10.1038/nmeth989
Symmetric spike timing-dependent plasticity 1444 at CA3?CA3 synapses optimizes storage and recall in autoassociative networks, Nat. Commun, vol.7, 1445. ,
DOI : 10.1038/ncomms11552
URL : http://www.nature.com/articles/ncomms11552.pdf
Phenomenological models of synaptic plasticity 1447 based on spike timing, Biol. Cybern, vol.98, issue.459, pp.422-430, 2008. ,
DOI : 10.1007/s00422-008-0233-1
URL : https://link.springer.com/content/pdf/10.1007%2Fs00422-008-0233-1.pdf
Spike Timing-Dependent LTP/LTD Mediates Visual Experience-Dependent 1449, 2006. ,
DOI : 10.1016/j.neuron.2006.03.009
URL : https://doi.org/10.1016/j.neuron.2006.03.009
A model-based prediction of the calcium responses in https, 2013. ,
Do stars govern our actions? Astrocyte involvement in rodent behavior, Trends in Neurosciences, vol.38, issue.9, pp.535-549, 2015. ,
DOI : 10.1016/j.tins.2015.07.006
Astrocytic purinergic signaling coordinates synaptic networks, p.1476, 2005. ,
Neurotrophin regulation of neural circuit development and function, Nature Reviews Neuroscience, vol.24, issue.1, p.1478, 2013. ,
DOI : 10.1523/JNEUROSCI.1427-04.2004
The BDNF Val66Met Polymorphism Impairs Synaptic Transmission and Plasticity in the Infralimbic Medial Prefrontal Cortex, Journal of Neuroscience, vol.32, issue.7, pp.2410-2421, 2012. ,
DOI : 10.1523/JNEUROSCI.5205-11.2012
URL : http://www.jneurosci.org/content/jneuro/32/7/2410.full.pdf
Dopamine Receptor Activation Is Required for Corticostriatal 1483, 2008. ,
DOI : 10.1523/jneurosci.4402-07.2008
URL : http://www.jneurosci.org/content/jneuro/28/10/2435.full.pdf
Timing is not Everything: 1486 Neuromodulation Opens the STDP Gate. Front. Synaptic Neurosci. 2. 1487 https, 2010. ,
DOI : 10.3389/fnsyn.2010.00146
URL : https://doi.org/10.3389/fnsyn.2010.00146
Coupled phosphatase and kinase switches produce the tristability 1489 required for long-term potentiation and long-term depression, J. Neurosci. Off. J. Soc. Neurosci, 2008. ,
DOI : 10.1523/jneurosci.2348-08.2008
URL : http://www.jneurosci.org/content/jneuro/28/49/13132.full.pdf
NMDA receptor???dependent metaplasticity at hippocampal mossy fiber synapses, Nature Neuroscience, vol.14, issue.6, pp.691-693, 2011. ,
DOI : 10.1523/JNEUROSCI.4194-05.2006
Spike timing???dependent long-term depression requires presynaptic NMDA receptors, Nature Neuroscience, vol.18, issue.7, pp.744-745, 2008. ,
DOI : 10.1523/JNEUROSCI.3915-07.2008
Dopamine-enabled anti-Hebbian timing-dependent plasticity 1509 in prefrontal circuitry, Front. Neural Circuits, vol.8, 2014. ,
DOI : 10.3389/fncir.2014.00038
URL : http://journal.frontiersin.org/article/10.3389/fncir.2014.00038/pdf
Calcium Time Course as a Signal for Spike-Timing???Dependent Plasticity, Journal of Neurophysiology, vol.93, issue.5, pp.2600-2613, 2005. ,
DOI : 10.1038/25665
URL : http://jn.physiology.org/content/jn/93/5/2600.full.pdf
Timing dependence of the induction of cerebellar LTD, Neuropharmacology, vol.54, issue.1, 2008. ,
DOI : 10.1016/j.neuropharm.2007.05.029
What do we know about gliotransmitter release 1516 from astrocytes? Philos, Trans. R. Soc. Lond. B. Biol. Sci, vol.369, 1517. ,
DOI : 10.1098/rstb.2013.0592
URL : http://rstb.royalsocietypublishing.org/content/royptb/369/1654/20130592.full.pdf
Critical role 1519 of promoter IV-driven BDNF transcription in GABAergic transmission and synaptic plasticity in 1520 the prefrontal cortex, Proc. Natl. Acad. Sci. USA, pp.5942-5947, 2009. ,
Noradrenergic 'Tone' Determines Dichotomous Control 1523 of Cortical Spike-Timing-Dependent Plasticity. Sci. Rep. 2. https, 2012. ,
DOI : 10.1038/srep00417
URL : http://www.nature.com/articles/srep00417.pdf
Inhibitory control of site-specific synaptic plasticity in a model CA1 pyramidal neuron, Biosystems, vol.130, pp.37-50, 2015. ,
DOI : 10.1016/j.biosystems.2015.03.001
Unsupervised Learning in an Ensemble of 1540, 2016. ,
A unified model of NMDA receptor-dependent bidirectional synaptic plasticity, Proceedings of the National Academy of Sciences, vol.13, issue.4-5, pp.10831-10836, 2002. ,
DOI : 10.1016/S0893-6080(00)00028-9
URL : http://www.pnas.org/content/99/16/10831.full.pdf
Stochastic Properties of Synaptic Transmission Affect the Shape of Spike Time???Dependent Plasticity Curves, Journal of Neurophysiology, vol.93, issue.2, pp.1069-1073, 2005. ,
DOI : 10.1038/25665
Rate, Timing, and Cooperativity Jointly Determine Cortical Synaptic Plasticity, Neuron, vol.32, issue.6, pp.1149-1164, 2001. ,
DOI : 10.1016/S0896-6273(01)00542-6
Calcium-dependent calcium decay explains STDP 1557 in a dynamic model of hippocampal synapses, PloS One, vol.9, 2014. ,
The effect of coactivation of 1560 muscarinic and nicotinic acetylcholine receptors on LTD in the hippocampal CA1 network, Brain, 1561. ,
1649, Part A, pp.44-52 ,
Cholinergic modulation on spike Valtcheva 1579 Developmental control of spike-timing-dependent plasticity by tonic GABAergic signaling in 1580 striatum, Neuropharmacology, vol.121, pp.261-277, 2011. ,
Astrocytes gate Hebbian synaptic plasticity in the striatum, Nature Communications, vol.2014, 2016. ,
DOI : 10.1155/2014/232105
URL : https://hal.archives-ouvertes.fr/hal-01429821
Astrocytes as secretory cells of the central nervous system: idiosyncrasies of vesicular secretion, The EMBO Journal, vol.35, issue.3, pp.239-257, 2016. ,
DOI : 10.15252/embj.201592705
URL : https://hal.archives-ouvertes.fr/hal-01474303
Relevance of synaptic tagging and capture to the persistence of long-term potentiation and everyday spatial memory, Proceedings of the National Academy of Sciences, vol.27, issue.47, pp.19537-19542, 1589. ,
DOI : 10.1523/JNEUROSCI.4093-07.2007
The Back and Forth of Dendritic Plasticity, Neuron, vol.56, issue.6, pp.947-953, 2007. ,
DOI : 10.1016/j.neuron.2007.12.004
URL : https://doi.org/10.1016/j.neuron.2007.12.004
Malleability of Spike-Timing-Dependent Plasticity at the CA3-CA1 Synapse, Journal of Neuroscience, vol.26, issue.24, pp.6610-6617, 2006. ,
DOI : 10.1523/JNEUROSCI.5388-05.2006
URL : http://www.jneurosci.org/content/jneuro/26/24/6610.full.pdf
D1 and D2 dopamine receptors in separate circuits cooperate to drive 1600, 2010. ,
DOI : 10.1073/pnas.1004108107
URL : http://www.pnas.org/content/107/37/16366.full.pdf
