Journal articles
Three dimensional adaptive meshing scheme applied to the control of the spatial representation of complex field pattern in electromagnetics
Abstract : We present an improved adaptive mesh process based on Riemannian transformation to control the accuracy in high field gradient representation for diffraction problems. Such an adaptive meshing is applied in representing the electromagnetic intensity around a metallic submicronic spherical particle, which is known to present high gradients in limited zones of space including the interference pattern of the electromagnetic field. We show that, the precision of the field variation being controlled, this improved scheme permits drastically decreasing the computational time as well as the memory requirements by adapting the number and the position of nodes where the electromagnetic field must be computed and represented.
Complete list of metadata
https://hal.inria.fr/hal-01810040
Contributor : Thomas Grosges Connect in order to contact the contributor
Submitted on : Thursday, June 7, 2018 - 2:07:06 PM
Last modification on : Sunday, June 26, 2022 - 4:50:25 AM
Links full text
Identifiers
Collections
Citation
Houman Borouchaki, Dominique Barchiesi, Thomas Grosges. Three dimensional adaptive meshing scheme applied to the control of the spatial representation of complex field pattern in electromagnetics. Applied Physics B - Laser and Optics, Springer Verlag, 2010, 101 (4), pp.883 - 889. ⟨10.1007/s00340-010-4155-y⟩. ⟨hal-01810040⟩
Share
Metrics
Record views
38
