A loosely coupled scheme for fictitious domain approximations of fluid-structure interaction problems with immersed thin-walled structures - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue SIAM Journal on Scientific Computing Année : 2019
Fictitious domain approximations of fluid-structure interaction problems are generally discretized in time using strongly coupled schemes. This guarantees unconditional stability but at the price of solving a computationally demanding coupled system at each time-step. The design of loosely coupled schemes (i.e., methods that invoke the fluid and solid solvers only once per time-step) is of fundamental interest, especially for three-dimensional simulations, but the existing approaches are known to suffer from severe stability and/or time accuracy issues. We propose a new approach that overcomes these difficulties in the case of the coupling with immersed thin-walled structures.
M119277-gg (1).pdf (30.77 Mo) Télécharger le fichier
hal-01811290 , version 1 (08-06-2018)
hal-01811290 , version 2 (26-03-2019)
Ludovic Boilevin-Kayl, Miguel Angel Fernández, Jean-Frédéric Gerbeau. A loosely coupled scheme for fictitious domain approximations of fluid-structure interaction problems with immersed thin-walled structures. SIAM Journal on Scientific Computing, 2019, 41 (2), pp.351-374. ⟨10.1137/18M1192779⟩. ⟨hal-01811290v2⟩
598 Consultations
303 Téléchargements
