Nitsche-XFEM for the coupling of an incompressible fluid with immersed thin-walled structures, Computer Methods in Applied Mechanics and Engineering, vol.301, pp.300-335, 2016. ,
DOI : 10.1016/j.cma.2015.12.015
URL : https://hal.archives-ouvertes.fr/hal-01149225
Time integration schemes for fluid-structure interaction problems: non-fitted FEMs for immersed thin structures, 2017. ,
Fluid???structure interaction and multi-body contact: Application to aortic valves, Computer Methods in Applied Mechanics and Engineering, vol.198, issue.45-46 ,
DOI : 10.1016/j.cma.2008.09.012
URL : https://hal.archives-ouvertes.fr/inria-00542238
A fictitious domain/mortar element method for fluid-structure interaction, International Journal for Numerical Methods in Fluids, vol.79, issue.7, pp.743-761, 2001. ,
DOI : 10.1002/1097-0363(20010415)35:7<743::AID-FLD109>3.0.CO;2-A
Splitting Methods Based on Algebraic Factorization for Fluid-Structure Interaction, SIAM Journal on Scientific Computing, vol.30, issue.4, pp.1778-1805, 2008. ,
DOI : 10.1137/070680497
URL : http://infoscience.epfl.ch/record/103018/files/splitting_methos.pdf
An analysis of a new stable partitioned algorithm for FSI problems. Part II: Incompressible flow and structural shells, Journal of Computational Physics, vol.268, pp.399-416, 2014. ,
DOI : 10.1016/j.jcp.2014.03.004
Finite Element Procedures, 1996. ,
A three-dimensional fictitious domain method for incompressible fluid flow problems, International Journal for Numerical Methods in Fluids, vol.7, issue.6, pp.25-719, 1997. ,
DOI : 10.1093/imanum/4.4.441
FINITE ELEMENT APPROACH TO IMMERSED BOUNDARY METHOD WITH DIFFERENT FLUID AND SOLID DENSITIES, Mathematical Models and Methods in Applied Sciences, vol.21, issue.12, pp.2523-2550, 2011. ,
DOI : 10.1016/j.cma.2003.12.044
The Finite Element Immersed Boundary Method with Distributed Lagrange Multiplier, SIAM Journal on Numerical Analysis, vol.53, issue.6, pp.2584-2604, 2015. ,
DOI : 10.1137/140978399
URL : http://arxiv.org/pdf/1407.5184
A fictitious domain approach with Lagrange multiplier for fluid-structure interactions, Numerische Mathematik, vol.193, issue.232, pp.711-732, 2017. ,
DOI : 10.1016/j.cma.2003.12.024
URL : http://arxiv.org/pdf/1510.06856
Numerical methods for immersed FSI with thin-walled structures, Computers & Fluids, 2018. ,
DOI : 10.1016/j.compfluid.2018.05.024
URL : https://hal.archives-ouvertes.fr/hal-01704575
Fluid???structure interaction in blood flow capturing non-zero longitudinal structure displacement, Journal of Computational Physics, vol.235, pp.515-541, 2013. ,
DOI : 10.1016/j.jcp.2012.08.033
Stabilization of explicit coupling in fluid???structure interaction involving fluid incompressibility, Computer Methods in Applied Mechanics and Engineering, vol.198, issue.5-8, pp.766-784, 2009. ,
DOI : 10.1016/j.cma.2008.10.012
URL : https://hal.archives-ouvertes.fr/inria-00247409
An unfitted Nitsche method for incompressible fluid???structure interaction using overlapping meshes, Computer Methods in Applied Mechanics and Engineering, vol.279, pp.497-514, 2014. ,
DOI : 10.1016/j.cma.2014.07.007
URL : https://hal.archives-ouvertes.fr/hal-00918272
NURBS-based numerical proxies for red blood cells and circulating tumor cells in microscale blood flow, Computer Methods in Applied Mechanics and Engineering, vol.316, pp.316-646, 2017. ,
DOI : 10.1016/j.cma.2016.09.031
Added-mass effect in the design of partitioned algorithms for fluid???structure problems, Computer Methods in Applied Mechanics and Engineering, vol.194, issue.42-44, pp.4506-4527, 2005. ,
DOI : 10.1016/j.cma.2004.12.005
URL : https://hal.archives-ouvertes.fr/hal-00695954
A partitioned fluid???structure algorithm for elastic thin valves with contact, Computer Methods in Applied Mechanics and Engineering, vol.197, issue.19-20, pp.1750-1761, 2008. ,
DOI : 10.1016/j.cma.2007.03.019
URL : https://hal.archives-ouvertes.fr/hal-00701780
Approximation of Single Layer Distributions by Dirac Masses in Finite Element Computations, Journal of Scientific Computing, vol.197, issue.2, pp.25-40, 2014. ,
DOI : 10.1016/j.cma.2007.07.009
Incremental displacement-correction schemes for incompressible fluid-structure interaction, Numerische Mathematik, vol.17, issue.6, pp.21-65, 2013. ,
DOI : 10.1142/S0218202507002170
A projection semi-implicit scheme for the coupling of an elastic structure with an incompressible fluid, International Journal for Numerical Methods in Engineering, vol.9, issue.4, pp.794-821, 2007. ,
DOI : 10.1007/978-1-4757-4355-5
Splitting schemes for incompressible fluid/thin-walled structure interaction with unfitted meshes, Comptes Rendus Mathematique, vol.353, issue.7, pp.647-652, 2015. ,
DOI : 10.1016/j.crma.2015.04.003
Fully decoupled time-marching schemes for incompressible fluid/thin-walled structure interaction, Journal of Computational Physics, vol.297, pp.156-181, 2015. ,
DOI : 10.1016/j.jcp.2015.05.009
Explicit Robin???Neumann schemes for the coupling of incompressible fluids with thin-walled structures, Computer Methods in Applied Mechanics and Engineering, vol.267, pp.566-593, 2013. ,
DOI : 10.1016/j.cma.2013.09.020
Generalized Robin-Neumann explicit coupling schemes for incompressible fluid-structure interaction: Stability analysis and numerics, International Journal for Numerical Methods in Engineering, vol.38, issue.6-7, pp.199-229, 2015. ,
DOI : 10.1007/s00466-006-0066-5
Artificial added mass instabilities in sequential staggered coupling of nonlinear structures and incompressible viscous flows, Computer Methods in Applied Mechanics and Engineering, vol.196, issue.7 ,
DOI : 10.1016/j.cma.2006.09.002
An eXtended Finite Element Method/Lagrange multiplier based approach for fluid???structure interaction, Computer Methods in Applied Mechanics and Engineering, vol.197, issue.19-20, pp.1699-1714, 2008. ,
DOI : 10.1016/j.cma.2007.07.002
An enhanced Immersed Structural Potential Method for fluid???structure interaction, Journal of Computational Physics, vol.250, pp.178-205, 2013. ,
DOI : 10.1016/j.jcp.2013.05.011
URL : https://doi.org/10.1016/j.jcp.2013.05.011
A distributed Lagrange mutiplier/fictitious domain method for particulate flows, Int. J. of Multiphase Flow, pp.25-755, 1999. ,
DOI : 10.1016/s0301-9322(98)00048-2
Stable loosely-coupled-type algorithm for fluid???structure interaction in blood flow, Journal of Computational Physics, vol.228, issue.18, pp.6916-6937, 2009. ,
DOI : 10.1016/j.jcp.2009.06.007
On continuum immersed strategies for Fluid???Structure Interaction, Computer Methods in Applied Mechanics and Engineering, vol.247, issue.248, pp.247-248, 2012. ,
DOI : 10.1016/j.cma.2012.07.021
URL : https://doi.org/10.1016/j.cma.2012.07.021
A stabilised immersed framework on hierarchical b-spline grids for fluid-flexible structure interaction with solid???solid contact, Computer Methods in Applied Mechanics and Engineering, vol.335, pp.472-489, 2018. ,
DOI : 10.1016/j.cma.2018.02.021
An immersogeometric variational framework for fluid???structure interaction: Application to bioprosthetic heart valves, Computer Methods in Applied Mechanics and Engineering, vol.284, pp.284-1005, 2015. ,
DOI : 10.1016/j.cma.2014.10.040
URL : http://europepmc.org/articles/pmc4274080?pdf=render
Immersogeometric cardiovascular fluid???structure interaction analysis with divergence-conforming B-splines, Computer Methods in Applied Mechanics and Engineering, vol.314, pp.314-408, 2017. ,
DOI : 10.1016/j.cma.2016.07.028
URL : http://europepmc.org/articles/pmc5319417?pdf=render
A weak-coupling immersed boundary method for fluid???structure interaction with low density ratio of solid to fluid, Journal of Computational Physics, vol.359, pp.296-311, 2018. ,
DOI : 10.1016/j.jcp.2017.12.045
Coupling schemes for the FSI forward prediction challenge: Comparative study and validation, International Journal for Numerical Methods in Biomedical Engineering, vol.301, issue.45-46, pp.33-2813, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01239931
Fluid structure interaction with large structural displacements, Comput. Meth. Appl. Mech. Engrg, vol.190, pp.3039-3067, 2001. ,
An Eulerian???Lagrangian method for fluid???structure interaction based on level sets, Computer Methods in Applied Mechanics and Engineering, vol.195, issue.17-18, pp.2070-2087, 2006. ,
DOI : 10.1016/j.cma.2005.02.025
Lagrange multiplier method with penalty for elliptic and parabolic interface problems, Journal of Applied Mathematics and Computing, vol.43, issue.6, pp.37-56, 2011. ,
DOI : 10.1137/040605357
The immersed boundary method, Acta Numer, vol.11, pp.479-517, 2002. ,
A SEMI-IMPLICIT APPROACH FOR FLUID-STRUCTURE INTERACTION BASED ON AN ALGEBRAIC FRACTIONAL STEP METHOD, Mathematical Models and Methods in Applied Sciences, vol.33, issue.06, pp.957-983, 2007. ,
DOI : 10.1016/j.cma.2005.05.050
LLM and X-FEM based interface modeling of fluid???thin structure interactions on a non-interface-fitted mesh, Computational Mechanics, vol.408, issue.EM3, pp.319-332, 2011. ,
DOI : 10.1038/35048530
Numerical solution of the obstacle problem by the penalty method, Computing, pp.32-297, 1984. ,
DOI : 10.1007/bf01389628
Stabilized Finite Element Formulations for Incompressible Flow Computations, Advances in applied mechanics, pp.1-44, 1992. ,
DOI : 10.1016/S0065-2156(08)70153-4
Galerkin finite element methods for parabolic problems, of Springer Series in Computational Mathematics, 2006. ,
DOI : 10.1007/978-3-662-03359-3
Added Mass Effects of Compressible and Incompressible Flows in Fluid-Structure Interaction, Journal of Applied Mechanics, vol.195, issue.2, pp.21206-21213, 2009. ,
DOI : 10.1137/S1064827503431430
Flapping and contact FSI computations with the fluid???solid interface-tracking/interface-capturing technique and mesh adaptivity, Computational Mechanics, vol.227, issue.6, pp.29-43, 2014. ,
DOI : 10.1016/j.jcp.2007.11.019
The enriched space???time finite element method (EST) for simultaneous solution of fluid???structure interaction, International Journal for Numerical Methods in Engineering, vol.90, issue.3, pp.75-305, 2008. ,
DOI : 10.1002/nme.2258
URL : https://hal.archives-ouvertes.fr/hal-01371129
