Nitsche-XFEM for the 672 coupling of an incompressible fluid with immersed thin-walled structures, Comput. Meth-673 ods Appl. Mech. Engrg, vol.301, pp.300-335, 2016. ,
Time integration schemes for fluid-structure interaction problems: Non-fitted 675 ,
, FEMs for immersed thin structures, p.676, 2017.
Fluid-structure interaction and 677 multi-body contact: Application to aortic valves, Comput. Methods Appl. Mech. Engrg, vol.678, pp.3603-3612, 2009. ,
A fictitious domain/mortar element method for fluid-structure interaction ,
, J. Numer. Methods Fluids, vol.35, pp.743-761, 2001.
Splitting methods based on algebraic factorization 682 for fluid-structure interaction, SIAM J. Sci. Comput, vol.30, pp.1778-1805, 2008. ,
An analysis of a new stable partitioned 684 algorithm for FSI problems. Part II: Incompressible flow and structural shells, J. Comput ,
, , vol.268, pp.399-416, 2014.
, Finite Element Procedures, p.687, 1996.
A three-dimensional fictitious domain 688 method for incompressible fluid flow problems, Int. J. Numer. Methods Fluids, vol.25, pp.719-736, 1997. ,
DOI : 10.1002/(sici)1097-0363(19970930)25:6<719::aid-fld585>3.0.co;2-k
Finite element approach to immersed boundary 691 method with different fluid and solid densities, Math. Models Methods Appl. Sci, vol.21, pp.692-2523, 2011. ,
The finite element immersed boundary method 694 with distributed Lagrange multiplier, SIAM J. Numer. Anal, vol.53, pp.2584-2604, 2015. ,
A fictitious domain approach with lagrange multiplier for fluid-696 structure interactions, Numer. Math, vol.135, pp.711-732, 2017. ,
DOI : 10.1007/s00211-016-0814-1
URL : http://arxiv.org/pdf/1510.06856
Numerical methods for immersed 698 FSI with thin-walled structures, Comput. Fluids, 2018. ,
DOI : 10.1016/j.compfluid.2018.05.024
URL : https://hal.inria.fr/hal-01704575/file/RR-9151.pdf
Fluid-structure interaction 701 in blood flow capturing non-zero longitudinal structure displacement, J. Comp. Phys, vol.235, pp.515-541, 2013. ,
Stabilization of explicit coupling in fluid-structure interac-704 tion involving fluid incompressibility, Comput. Methods Appl. Mech. Engrg, vol.198, pp.705-766, 2009. ,
An unfitted Nitsche method for incompressible fluid-707 structure interaction using overlapping meshes, Comput. Methods Appl. Mech. Engrg, vol.708, pp.497-514, 2014. ,
DOI : 10.1016/j.cma.2014.07.007
URL : https://doi.org/10.1016/j.cma.2014.07.007
NURBS-based numerical proxies for red blood 710 cells and circulating tumor cells in microscale blood flow, Comput. Methods Appl. Mech ,
DOI : 10.1016/j.cma.2016.09.031
, , pp.646-667, 2017.
Added-mass effect in the design of partitioned 713 algorithms for fluid-structure problems, Comput. Methods Appl. Mech. Engrg, vol.194, pp.714-4506, 2005. ,
A partitioned fluid-structure al-716 gorithm for elastic thin valves with contact, Comput. Methods Appl. Mech. Engrg, vol.197, pp.1750-1761, 2008. ,
Approximation of single layer distributions by dirac masses in 719 finite element computations, J. Sci. Comput, vol.58, pp.25-40, 2014. ,
Incremental displacement-correction schemes for incompressible fluid-721 structure interaction: stability and convergence analysis, Numer. Math, vol.123, pp.722-743, 2013. ,
A projection semi-implicit scheme for 724 the coupling of an elastic structure with an incompressible fluid, Int. J. Numer. Methods 725 Engrg, vol.69, pp.794-821, 2007. ,
Splitting schemes for incompressible fluid/thin-walled 727 structure interaction with unfitted meshes, C. R. Math. Acad. Sci. Paris, vol.353, pp.647-652, 2015. ,
Fully decoupled time-marching 730 schemes for incompressible fluid/thin-walled structure interaction, J. Comput. Phys, vol.297, pp.156-181, 2015. ,
Convergence and error analysis for a class of split-733 ting schemes in incompressible fluid-structure interaction, J. Numer. Anal, vol.36, pp.734-1748, 2016. ,
Explicit Robin-Neumann schemes for 736 the coupling of incompressible fluids with thin-walled structures, Comput. Methods Appl ,
, Mech. Engrg, vol.267, pp.566-593, 2013.
Generalized Robin-Neumann explicit 739 coupling schemes for incompressible fluid-structure interaction: Stability analysis and 740 numerics, Int. J. Numer. Methods Engrg, vol.101, pp.199-229, 2015. ,
Artificial added mass instabilities in sequential staggered 742 coupling of nonlinear structures and incompressible viscous flows, Comput. Methods Appl ,
, Mech. Engrg, vol.196, pp.1278-1293, 2007.
An extended finite element method/Lagrange multiplier 745 based approach for fluid-structure interaction, Comput. Methods Appl. Mech. Engrg, vol.197, pp.1699-1714, 2008. ,
DOI : 10.1016/j.cma.2007.07.002
, tural Potential Method for fluid-structure interaction, J. Comput. Phys, vol.250, pp.749-178, 2013.
A distributed Lagrange mutiplier/fictitious 751 domain method for particulate flows, Int. J. Multiphase Flow, vol.25, pp.755-794, 1999. ,
Stable loosely-coupled-type 753 algorithm for fluid-structure interaction in blood flow, J. Comp. Phys, vol.228, pp.754-6916, 2009. ,
On continuum immersed strategies 756 for Fluid-Structure Interaction, Comput. Methods Appl. Mech. Engrg, pp.757-51, 2012. ,
A stabilised immersed framework on hierarchi-759 ,
, cal b-spline grids for fluid-flexible structure interaction with solid-solid contact
, Methods Appl. Mech. Engrg, vol.335, pp.472-489, 2018.
An immersogeometric variational framework for fluid-structure interac-763 tion: Application to bioprosthetic heart valves, Comput. Methods Appl. Mech. Engrg, vol.284, pp.1005-1053, 2015. ,
Immersogeometric 766 cardiovascular fluid-structure interaction analysis with divergence-conforming B-splines, p.767 ,
DOI : 10.1016/j.cma.2016.07.028
URL : http://europepmc.org/articles/pmc5319417?pdf=render
, Comput. Methods Appl. Mech. Engrg, vol.314, pp.408-472, 2017.
A weak-coupling immersed boundary method for fluidstruc-769 ture interaction with low density ratio of solid to fluid, J. Comput. Phys, vol.359, pp.770-296, 2018. ,
Coupling schemes for 772 the FSI forward predication challenge: Comparative study and validation, Int. J. Numer ,
, Methods Biomed. Engrg, vol.33, p.23, 2017.
Coupling schemes for 775 the FSI forward prediction challenge: comparative study and validation, Int. J. Numer ,
, Methods Biomed. Engrg, vol.33, p.2813, 2017.
Fluid structure interaction with large structural displacements, p.778 ,
, Comput. Methods Appl. Mech. Engrg, vol.190, pp.3039-3067, 2001.
An Eulerian-Lagrangian method for fluid-780 structure interaction based on level sets, Comput. Methods Appl. Mech. Engrg, vol.195, pp.781-2070, 2006. ,
An effective fluid-structure interaction formulation for vascular 783 dynamics by generalized Robin conditions, SIAM J. Sci. Comput, vol.30, pp.731-763, 2008. ,
Lagrange multiplier method with penalty for elliptic and parabolic interface problems, p.785 ,
, J. Appl. Math. Comput, vol.37, pp.37-56, 2011.
The immersed boundary method, Acta Numer, vol.11, pp.479-517, 2002. ,
A semi-implicit approach for fluid-structure interaction based 788 on an algebraic fractional step method, Math. Models Methods Appl. Sci, vol.17, pp.789-957, 2007. ,
LLM and X-FEM based interface modeling of fluid-thin structure 791 interactions on a non-interface-fitted mesh, Comput. Mech, vol.48, pp.319-332, 2011. ,
Numerical solution of the obstacle problem by the penalty method, Computing, vol.32, pp.297-306, 1984. ,
Stabilized finite element formulations for incompressible flow computations, 795 Advances in Applied Mechanics, vol.28, pp.1-44, 1992. ,
Galerkin finite element methods for parabolic problems, Springer Series in Com-797 putational Mathematics 25, 2006. ,
Added mass effects of compressible and incompressible flows in fluid-799 structure interaction, J. Appl. Mech, vol.76, pp.21206-21213, 2009. ,
Flapping and contact FSI computations with the fluid-solid interface-801 tracking/interface-capturing technique and mesh adaptivity, Comput. Mech, vol.53, pp.29-43, 2014. ,
The enriched space-time finite element method (EST) for simulta-804 neous solution of fluid-structure interaction, Int. J. Numer. Methods Engrg, vol.75, pp.305-334, 2008. ,
