Feature extraction and tracking of CNN segmentations for improved road detection from satellite imagery
Road detection in high-resolution satellite images is an important and popular research topic in the field of image processing. In this paper, we propose a novel road extraction and tracking method based on road segmentation results from a convolutional network, providing improved road detection. The proposed method incorporates our previously proposed connected-tube marked point process (MPP) model and a post-tracking algorithm. We present experimental results on the Massachusetts roads dataset to show the performance of our method on road detection in remotely-sensed images.
A CONNECTED-TUBE MPP MODEL FOR OBJECT DETECTION WITH APPLICATION TO MATERIALS AND REMOTELY-SENSED IMAGES.pdf (2.04 Mo)
Télécharger le fichier
