A proof theory for model checking - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Automated Reasoning Année : 2019
While model checking has often been considered as a practical alternative to building formal proofs, we argue here that the theory of sequent calculus proofs can be used to provide an appealing foundation for model checking. Since the emphasis of model checking is on establishing the truth of a property in a model, we rely on additive inference rules since these provide a natural description of truth values via inference rules. Unfortunately, using these rules alone can force the use of inference rules with an infinite number of premises. In order to accommodate more expressive and finitary inference rules, we also allow multiplicative rules but limit their use to the construction of additive synthetic inference rules: such synthetic rules are described using the proof-theoretic notions of polarization and focused proof systems. This framework provides a natural, proof-theoretic treatment of reachability and non-reachability problems, as well as tabled deduction, bisimulation, and winning strategies.
hal.pdf (424.52 Ko) Télécharger le fichier
hal-01814006 , version 1 (12-06-2018)
Quentin Heath, Dale Miller. A proof theory for model checking. Journal of Automated Reasoning, 2019, 63 (4), pp.857-885. ⟨10.1007/s10817-018-9475-3⟩. ⟨hal-01814006⟩
258 Consultations
486 Téléchargements
