Enable Polyhedral Optimizations in XLA through LLVM/Polly. Google Summer of Code 2017 final report, 2017. ,
Automatic Translation of FORTRAN Programs to Vector Form, Transactions on Programming Languages and Systems (TOPLAS), vol.9, pp.491-542, 1987. ,
Improved Loop Tiling Based on the Removal of Spurious False Dependences, Transactions on Architecture and Code Optimization (TACO), vol.9, pp.1-52, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-00786674
Tiling Stencil Computations to Maximize Parallelism, International Conference for High Performance Computing, Networking, Storage and Analysis (SC), pp.1-11, 2012. ,
Automatic C-to-CUDA code generation for affine programs, Compiler Construction, pp.244-263, 2010. ,
Automatic Storage Optimization for Arrays, Transactions on Architecture and Code Optimization (TACO), vol.38, pp.1-11, 2016. ,
SMO: An Integrated Approach to Intra-Array and InterArray Storage Optimization, Proceedings of the 43rd Annual ACM SIGPLAN-SIGACT Symposium on Principles of Programming Languages (POPL '16), pp.526-538, 2016. ,
A Model for Fusion and Code Motion in an Automatic Parallelizing Compiler, Proceedings of the 19th International Conference on Parallel Architectures and Compilation Techniques (PACT '10), pp.343-352, 2010. ,
A Practical Automatic Polyhedral Parallelizer and Locality Optimizer, SIGPLAN Notices, vol.43, pp.101-113, 2008. ,
Register Allocation via Coloring, Computer Languages, vol.6, pp.47-57, 1981. ,
Extended Lattice-Based Memory Allocation, Proceedings of the 25th International Conference on Compiler Construction, pp.218-228, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01272969
Some Efficient Solutions to the Affine Scheduling Problem-Part I. One-dimensional Time, International Journal of Parallel Programming, vol.21, pp.313-347, 1992. ,
Some Efficient Solutions to the Affine Scheduling Problem-Part II. Multidimensional Time, International Journal of Parallel Programming, vol.21, pp.389-420, 1992. ,
Array Expansion, International Conference on Supercomputing 25th Anniversary Volume (SC '14, pp.99-111, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-01099746
Polly-Performing Polyhedral Optimizations on a Low-Level Intermediate Representation, Parallel Processing Letters, vol.22, p.4, 2012. ,
Array SSA Form and Its Use in Parallelization, Proceedings of the 25th ACM SIGPLAN-SIGACT Symposium on Principles of Programming Languages (POPL '98, pp.107-120, 1998. ,
, , 2017.
Dependence Graphs and Compiler Optimizations, Proceedings of the 8th ACM SIGPLAN-SIGACT Symposium on Principles of Programming Languages (POPL '81), pp.207-218, 1981. ,
Automatic storage management for parallel programs, Parallel Comput, vol.24, pp.649-671, 1998. ,
Array Privatization: A Loop Transformation for Parallel Execution, 1992. ,
Variable Liberalization. Transactions on Architecture and Code Optimization (TACO) 13, 3, Article 23, vol.23, pp.1-23, 2016. ,
Polymage: Automatic Optimization for Image Processing Pipelines, SIGPLAN Notices, vol.50, pp.429-443, 2015. ,
An Optimizing Code Generator for a Class of LatticeBoltzmann Computations, Transactions on Architecture and Code Optimization (TACO), vol.12, p.14, 2015. ,
, , 2016.
Optimizing Memory Usage in the Polyhedral Model, Transactions on Architecture and Code Optimization (TACO), vol.22, pp.773-815, 2000. ,
Graphite Two Years After: First Lessons learned from Real-World Polyhedral Compilation, GCC Research Opportunities Workshop (GROW '10), 2010. ,
URL : https://hal.archives-ouvertes.fr/inria-00551516
Elimination of Memory-Based Dependences for Loop-Nest Optimization and Parallelization, 3rd Workshop on GCC Research Opportunities (GROW '11), 2011. ,
URL : https://hal.archives-ouvertes.fr/hal-00992740
Transformation to Dynamic Single Assignment Using a Simple Data Flow Analysis, Programming Languages and Systems: Third Asian Symposium, pp.330-346, 2005. ,
Trading Off Memory For Parallelism Quality, International Workshop on Polyhedral Compilation Techniques, 2012. ,
Loop and Data Transformations for Sparse Matrix Code, SIGPLAN Notices, vol.50, pp.521-532, 2015. ,
Presburger Formulas and Polyhedral Compilation, 2016. ,
Polyhedral Parallel Code Generation for CUDA, Transactions on Architecture and Code Optimization (TACO), vol.9, p.54, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-00786677
Live Range Reordering, International Workshop on Polyhedral Compilation Techniques (IMPACT '16), 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01257224
Allocating Memory Arrays for Polyhedra, 1993. ,
