Counting points on genus-3 hyperelliptic curves with explicit real multiplication
Simon Abelard 1 Pierrick Gaudry 1 Pierre-Jean Spaenlehauer 1
1 CARAMBA - Cryptology, arithmetic : algebraic methods for better algorithms
Inria Nancy - Grand Est, LORIA - ALGO - Department of Algorithms, Computation, Image and Geometry
Abstract : We propose a Las Vegas probabilistic algorithm to compute the zeta function of a genus-3 hyperelliptic curve defined over a finite field Fq, with explicit real multiplication by an order Z[η] in a totally real cubic field. Our main result states that this algorithm requires an expected number of O((log q) 6) bit-operations, where the constant in the O() depends on the ring Z[η] and on the degrees of polynomials representing the endomorphism η. As a proof-of-concept, we compute the zeta function of a curve defined over a 64-bit prime field, with explicit real multiplication by Z[2 cos(2π/7)].
Type de document :
Communication dans un congrès
Thirteenth Algorithmic Number Theory Symposium ANTS-XIII, Jul 2018, Madison, United States
Liste complète des métadonnées
Littérature citée [31 références]  Voir  Masquer  Télécharger
https://hal.inria.fr/hal-01816256
Contributeur : Pierre-Jean Spaenlehauer <>
Soumis le : vendredi 15 juin 2018 - 09:11:28
Dernière modification le : mardi 18 décembre 2018 - 16:18:26
Document(s) archivé(s) le : lundi 17 septembre 2018 - 16:00:43
Fichier
RMg3.pdf
Fichiers produits par l'(les) auteur(s)
  • HAL Id : hal-01816256, version 1
Citation
Simon Abelard, Pierrick Gaudry, Pierre-Jean Spaenlehauer. Counting points on genus-3 hyperelliptic curves with explicit real multiplication. Thirteenth Algorithmic Number Theory Symposium ANTS-XIII, Jul 2018, Madison, United States. 〈hal-01816256v1〉
Métriques
Consultations de la notice
71
Téléchargements de fichiers
16
