Fast Coefficient Computation for Algebraic Power Series in Positive Characteristic - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We revisit Christol's theorem on algebraic power series in positive characteristic and propose yet another proof for it. This new proof combines several ingredients and advantages of existing proofs, which make it very well-suited for algorithmic purposes. We apply the construction used in the new proof to the design of a new efficient algorithm for computing the $N$th coefficient of a given algebraic power series over a perfect field of characteristic~$p$. It has several nice features: it is more general, more natural and more efficient than previous algorithms. Not only the arithmetic complexity of the new algorithm is linear in $\log N$ and quasi-linear in~$p$, but its dependency with respect to the degree of the input is much smaller than in the previously best algorithm. {Moreover, when the ground field is finite, the new approach yields an even faster algorithm, whose bit complexity is linear in $\log N$ and quasi-linear in~$\sqrt{p}$}.
fastNth.pdf (255.37 Ko) Télécharger le fichier
hal-01816375 , version 1 (15-06-2018)
Alin Bostan, Xavier Caruso, Gilles Christol, Philippe Dumas. Fast Coefficient Computation for Algebraic Power Series in Positive Characteristic. ANTS-XIII - Thirteenth Algorithmic Number Theory Symposium, Jul 2018, Madison, United States. pp.119-135, ⟨10.2140/obs.2019.2-1⟩. ⟨hal-01816375⟩
215 Consultations
155 Téléchargements
