Self-consistent method for density estimation, Journal of the Royal Statistical Society: Series B (Statistical Methodology), vol.34, issue.3, pp.407-422, 2011. ,
DOI : 10.1214/aoms/1177704159
Nonparametric statistics for stochastic processes: estimation and prediction, 2012. ,
An algorithm for the machine calculation of complex Fourier series, Mathematics of Computation, vol.19, issue.90, pp.297-301, 1965. ,
DOI : 10.1090/S0025-5718-1965-0178586-1
A Note on Inverse Moments of Binomial Variates, Brazilian Review of Econometrics, vol.20, issue.2, pp.269-277, 2000. ,
DOI : 10.12660/bre.v20n22000.2760
Kernel density estimator in an infinite-dimensional space with a rate of convergence in the case of diffusion process, Applied Mathematics Letters, vol.17, issue.4, pp.381-386, 2004. ,
DOI : 10.1016/S0893-9659(04)90078-X
On the using of modal curves for radar waveforms classification, Computational Statistics & Data Analysis, vol.51, issue.10, pp.4878-4890, 2007. ,
DOI : 10.1016/j.csda.2006.07.012
URL : https://hal.archives-ouvertes.fr/hal-00635607
Fast Fourier Transforms for Nonequispaced Data, SIAM Journal on Scientific Computing, vol.14, issue.6, pp.1368-1393, 1993. ,
DOI : 10.1137/0914081
URL : http://www.dtic.mil/cgi-bin/GetTRDoc?AD=ADA272687&Location=U2&doc=GetTRDoc.pdf
Curves discrimination: a nonparametric functional approach, Computational Statistics & Data Analysis, vol.44, issue.1-2, pp.161-173, 2003. ,
DOI : 10.1016/S0167-9473(03)00032-X
Correction of Density Estimators that are not Densities, Scandinavian Journal of Statistics, vol.8, issue.2, pp.415-427, 2003. ,
DOI : 10.1002/9780470317020
Accelerating the Nonuniform Fast Fourier Transform, SIAM Review, vol.46, issue.3, pp.443-454, 2004. ,
DOI : 10.1137/S003614450343200X
URL : http://math.nyu.edu/faculty/greengar/glee_nufft_sirev.pdf
Grouped variable importance with random forests and application to multiple functional data analysis, Computational Statistics & Data Analysis, vol.90, pp.15-35, 2015. ,
DOI : 10.1016/j.csda.2015.04.002
URL : https://hal.archives-ouvertes.fr/hal-01084301
Estimating and depicting the structure of a distribution of random functions, Biometrika, vol.89, issue.1, pp.145-158, 2002. ,
DOI : 10.1093/biomet/89.1.145
Lecture notes on " Mouvement brownien et calcul stochastique, 2007. ,
A least-squares approach to direct importance estimation, Journal of Machine Learning Research, vol.10, pp.1391-1445, 2009. ,
A Python Package for Density Ratio Estimation Dowloaded on may 4th 2018. URL https://github.com/hoxo-m/densratio_py Nicol, F., 2013. Functional principal component analysis of aircraft trajectories, Proceedings of the 2nd International Conference on Interdisciplinary Science for Innovative Air Traffic Management (ISIATM), 2016. ,
Reducing the Computational Cost of the ECF Using a nuFFT: A Fast and Objective Probability Density Estimation Method, Computational Statistics & Data Analysis, vol.79, pp.222-234, 2014. ,
A fast and objective multidimensional kernel density estimation method: fastkde, Computational Statistics & Data Analysis, vol.101, pp.148-160, 2016. ,
Scikit-learn: Machine learning in Python, JMLR, vol.12, pp.2825-2830, 2011. ,
URL : https://hal.archives-ouvertes.fr/hal-00650905
Nonparametric density estimation for functional data by delta sequences, Brazilian Journal of Probability and Statistics, vol.24, issue.3, pp.468-478, 2010. ,
Nonparametric density estimation for functional data via wavelets, Communications in Statistics?Theory and Methods, vol.3989, pp.1608-1618, 2010. ,
Applied functional data analysis: methods and case studies, 2007. ,
DOI : 10.1007/b98886
Aircraft dynamics identification for optimal control, Proceedings of the 7th European Conference for Aeronautics and Aerospace Sciences, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01639731
Multivariate density estimation: theory, practice, and visualization, 2015. ,
DOI : 10.1002/9781118575574
Density Estimation for Statistics and Data Analysis, 1986. ,
DOI : 10.1007/978-1-4899-3324-9
An Asymptotically Optimal Window Selection Rule for Kernel Density Estimates, The Annals of Statistics, vol.12, issue.4, pp.1285-1297, 1984. ,
DOI : 10.1214/aos/1176346792
URL : http://doi.org/10.1214/aos/1176346792
Conditional density estimation via least-squares density ratio estimation, Proceedings of the Thirteenth International Conference on Artificial Intelligence and Statistics, pp.781-788, 2010. ,
