A scalable clustering-based task scheduler for homogeneous processors using DAG partitioning - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2018
Un ordonnanceur de liste basé sur le partitionnement de DAGs pour des processeurs homogènes
When scheduling a directed acyclic graph (DAG) of tasks on computational platforms, a good trade-off between load balance and data locality is necessary. List-based scheduling techniques are commonly used greedy approaches for this problem. The downside of list-scheduling heuristics is that they are incapable of making short-term sacrifices for the global efficiency of the schedule. In this work, we describe new list-based scheduling heuristics based on clustering for homogeneous platforms, under the realistic duplex single-port communication model. Our approach uses an acyclic partitioner for DAGs for clustering. The clustering enhances the data locality of the scheduler with a global view of the graph. Furthermore, since the partition is acyclic, we can schedule each part completely once its input tasks are ready to be executed. We present an extensive experimental evaluation showing the trade-offs between the granularity of clustering and the parallelism, and how this affects the scheduling. Furthermore, we compare our heuristics to the best state-of-the-art list-scheduling and clustering heuristics, and obtain more than three times better makespan in cases with many communications.
Lors de l'ordonnancement d'un graphe dirigé acyclique (DAG) de tâches sur une plate-forme, un bon compromis entre équilibrage de charge et localité des données est nécessaire. Les techniques d'ordonnancement de liste sont des approches gloutonnes communément utilisées pour ce problème. Les inconvénients de telles heuristiques de liste sont qu'elles sont incapables de faire des sacrifices à court terme pour que l'ordonnancement global soit plus efficace. Dans ces travaux, nous décrivons de nouvelles heuristiques d'ordonnancement de liste pour des plates-formes homogènes, avec un modèle de communications duplexe un-port réaliste. Notre approche se base sur un partitionnement acyclique du DAG, car les parties ainsi formées permettent d'avoir une bonne localité des données tout en conservant une vue générale du graphe. De plus, étant donné que la partition est acyclique, nous pouvons ordonnancer chaque partie entièrement une fois que ses tâches d'entrée sont prêtes à être exécutées. Nous présentons une évaluation expérimentale des algorithmes pour montrer les compromis entre la granularité des partitions et le parallélisme, et comment cela affecte l'ordonnancement. De plus, nous comparons nos heuristiques aux meilleurs compétiteurs de la littérature, et nous obtenons un temps d’exécution total plus de trois fois meilleur dans des cas avec de nombreuses communications.
RR-9185-v3.pdf (1.77 Mo) Télécharger le fichier
hal-01817501 , version 1 (18-06-2018)
hal-01817501 , version 2 (18-10-2018)
hal-01817501 , version 3 (15-01-2019)
  • HAL Id : hal-01817501 , version 3
Yusuf M. Özkaya, Anne Benoit, Bora Uçar, Julien Herrmann, Ümit V. Çatalyürek. A scalable clustering-based task scheduler for homogeneous processors using DAG partitioning. [Research Report] RR-9185, Inria Grenoble Rhône-Alpes. 2018, pp.1-34. ⟨hal-01817501v3⟩
355 Consultations
935 Téléchargements
