A comparison of list schedules for parallel processing systems, Communications of the ACM, vol.17, issue.12, pp.685-690, 1974. ,
On exploiting task duplication in parallel program scheduling, IEEE T. Parall. Distr, vol.9, issue.9, pp.872-892, 1998. ,
The University of Florida sparse matrix collection, ACM Trans. Math. Softw, vol.38, issue.1, 2011. ,
Benchmarking optimization software with performance profiles. Mathematical programming, vol.91, pp.201-213, 2002. ,
End-to-end quality of service for high-end applications, Computer Communications, vol.27, issue.14, pp.1375-1388, 2004. ,
Computers and Intractability, a Guide to the Theory of NP-Completeness, 1979. ,
On the granularity and clustering of directed acyclic task graphs, IEEE T. Parall. Distr, vol.4, issue.6, pp.686-701, 1993. ,
Flexible and efficient workflow deployement of data-intensive applications on grids with MOTEUR. Int, Journal of High Performance Computing and Applications, 2008. ,
URL : https://hal.archives-ouvertes.fr/hal-00459130
Bounds on multiprocessing timing anomalies, SIAM Journal on Applied Mathematics, vol.17, issue.2, pp.416-429, 1969. ,
An approximation algorithm for scheduling dependent tasks on m processors with small communication delays, Proceedings 1995 INRIA/IEEE Symposium on Emerging Technologies and Factory Automation. ETFA'95, vol.1, pp.167-189, 1995. ,
URL : https://hal.archives-ouvertes.fr/hal-01185825
Acyclic partitioning of large directed acyclic graphs, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01672010
Scheduling precedence graphs in systems with interprocessor communication times, SIAM Journal on Computing, vol.18, issue.2, pp.244-257, 1989. ,
DOI : 10.1137/0218016
Precedence scheduling with unit execution time is equivalent to parametrized biclique, SOFSEM 2016: Theory and Practice of Computer Science, pp.329-343, 2016. ,
DOI : 10.1007/978-3-662-49192-8_27
Clustering-based task scheduling in a large number of heterogeneous processors, IEEE T. Parall. Distr, vol.27, issue.11, pp.3144-3157, 2016. ,
Dynamic critical-path scheduling: An effective technique for allocating task graphs to multiprocessors, IEEE T. Parall. Distr, vol.7, issue.5, pp.506-521, 1996. ,
Benchmarking and comparison of the task graph scheduling algorithms, Journal of Parallel and Distributed Computing, vol.59, issue.3, pp.381-422, 1999. ,
DOI : 10.1006/jpdc.1999.1578
URL : http://www.eee.hku.hk/~ykwok/papers/compare-jpdc.pdf
Static scheduling algorithms for allocating directed task graphs to multiprocessors, ACM Comput. Surv, vol.31, issue.4, pp.406-471, 1999. ,
DOI : 10.1145/344588.344618
URL : http://reptar.uta.edu/NOTES4351/taskSurvey.pdf
An efficient parallel scheduling algorithm of dependent task graphs, Proc. of 4th Int. Conf. on Parallel and Distributed Computing, Applications and Technologies, PDCAT, pp.595-598, 2003. ,
New complexity results on scheduling with small communication delays, Discrete Applied Mathematics, vol.60, issue.1, pp.331-342, 1995. ,
DOI : 10.1016/0166-218x(94)00063-j
URL : https://doi.org/10.1016/0166-218x(94)00063-j
Low-cost task scheduling for distributed-memory machines, IEEE T. Parall. Distr, vol.13, issue.6, pp.648-658, 2002. ,
DOI : 10.1109/tpds.2002.1011417
URL : http://rama.pds.twi.tudelft.nl/~gemund/Publications/tpds02.pdf
Partitioning and scheduling parallel programs for execution on multiprocessors, 1987. ,
A compile-time scheduling heuristic for interconnection-constrained heterogeneous processor architectures, IEEE T. Parall. Distr, vol.4, issue.2, pp.175-187, 1993. ,
DOI : 10.1109/71.207593
Task Scheduling for Parallel Systems, Wiley Series on Par.and Distr. Computing, 2007. ,
DOI : 10.1002/0470121173
URL : https://onlinelibrary.wiley.com/doi/pdf/10.1002/9780470121177.fmatter
Conditional hardness of precedence constrained scheduling on identical machines, Proceedings of the Forty-second ACM Symposium on Theory of Computing, STOC'10, pp.745-754, 2010. ,
DOI : 10.1145/1806689.1806791
URL : http://www.nada.kth.se/~osven/papers/PCmaxFull5Nov.pdf
Performance-effective and low-complexity task scheduling for heterogeneous computing, IEEE T. Parall. Distr, vol.13, issue.3, pp.260-274, 2002. ,
DOI : 10.1109/71.993206
URL : http://meseec.ce.rit.edu/eecc722-fall2002/papers/hc/5/l0260.pdf
List-scheduling vs. cluster-scheduling, IEEE T. Parall. Distr, 2018. ,
Hypertool: A programming aid for message-passing systems, IEEE T. Parall. Distr, vol.1, issue.3, pp.330-343, 1990. ,
DOI : 10.1109/71.80160
URL : http://www.eece.unm.edu/~shu/lab/paper/htooltrans.pdf
DSC: Scheduling parallel tasks on an unbounded number of processors, IEEE T. Parall. Distr, vol.5, issue.9, pp.951-967, 1994. ,
Graph traversal based data race detection for asynchronous many-task runtimes, Euro-Par 2018: Parallel Processing, 2018. ,
DOI : 10.1007/978-3-319-96983-1_5
