Principal process analysis of biological models - Archive ouverte HAL Access content directly
Journal Articles BMC Systems Biology Year : 2018
(1, 2) , (3, 1, 2) , (4) , (1, 2)
1
2
3
4
Background: Understanding the dynamical behaviour of biological systems is challenged by their large number of components and interactions. While efforts have been made in this direction to reduce model complexity, they often prove insufficient to grasp which and when model processes play a crucial role. Answering these questions is fundamental to unravel the functioning of living organisms. Results: We design a method for dealing with model complexity, based on the analysis of dynamical models by means of Principal Process Analysis. We apply the method to a well-known model of circadian rhythms in mammals. The knowledge of the system trajectories allows us to decompose the system dynamics into processes that are active or inactive with respect to a certain threshold value. Process activities are graphically represented by Boolean and Dynamical Process Maps. We detect model processes that are always inactive, or inactive on some time interval. Eliminating these processes reduces the complex dynamics of the original model to the much simpler dynamics of the core processes, in a succession of sub-models that are easier to analyse. We quantify by means of global relative errors the extent to which the simplified models reproduce the main features of the original system dynamics and apply global sensitivity analysis to test the influence of model parameters on the errors. Conclusion: The results obtained prove the robustness of the method. The analysis of the sub-model dynamics allows us to identify the source of circadian oscillations. We find that the negative feedback loop involving proteins PER, CRY, CLOCK-BMAL1 is the main oscillator, in agreement with previous modelling and experimental studies. In conclusion, Principal Process Analysis is a simple-to-use method, which constitutes an additional and useful tool for analysing the complex dynamical behaviour of biological systems.
2018_Casagranda_BMC Systems Biology_1.pdf (5.22 Mo) Télécharger le fichier
Origin : Publisher files allowed on an open archive
Dates and versions
hal-01818033 , version 1 (26-05-2020)
Attribution - CC BY 4.0
Identifiers
Cite
Stefano Casagranda, Suzanne Touzeau, Delphine Ropers, Jean-Luc Gouzé. Principal process analysis of biological models. BMC Systems Biology, 2018, 12, pp.68. ⟨10.1186/s12918-018-0586-6⟩. ⟨hal-01818033⟩
142 View
77 Download
Share
