Ways of Visualizing Data on Curves - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2018
Charles Perin
Qiuyuan Ren
  • Fonction : Auteur
  • PersonId : 1033230
Pierre Dragicevic
This paper reviews the many ways curves are used to encode data in information visualization. As part of our review, we introduce a curve-based visualization framework where data can be encoded in two major ways: i) through a curve’s shape (a process we call embedding) and ii) through a curve’s local visual attributes (a process we call enrichment). Our framework helps describing and organizing the rich design space of curve-based data visualizations, and offer inspiration for novel data visualizations.
Bach2018ways (1).pdf (12.07 Mo) Télécharger le fichier
hal-01818137 , version 1 (18-06-2018)
Paternité
Benjamin Bach, Charles Perin, Qiuyuan Ren, Pierre Dragicevic. Ways of Visualizing Data on Curves. TransImage 2018 - 5th Biennial Transdisciplinary Imaging Conference, Apr 2018, Edinburgh, United Kingdom. pp.1-14, ⟨10.6084/m9.figshare.6104705⟩. ⟨hal-01818137⟩
230 Consultations
655 Téléchargements
